SpM Handbook
1.3.0
Searching...
No Matches
d_spm_integer.c
Go to the documentation of this file.
1
2
3
* @file d_spm_integer.c
4
5
* SParse Matrix package integer sorting routines.
6
7
* @copyright 2016-2026 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
8
* Univ. Bordeaux. All rights reserved.
9
10
* @version 1.3.0
11
* @author Mathieu Faverge
12
* @author Pierre Ramet
13
* @author Tony Delarue
14
* @author Alycia Lisito
15
* @date 2024-07-09
16
17
* @generated from /builds/fpruvost/spm/src/z_spm_integer.c, normal z -> d, Fri Oct 23 13:04:59 2026
18
19
20
#include "common.h"
21
22
23
24
25
* @fn void d_spmIntFltSortAsc(void ** const pbase, const spm_int_t n)
26
* @ingroup spm_dev_integer
27
* @brief Sort 2 arrays simultaneously, the first array is an array of
28
* spm_int_t and used as key for sorting. The second array is an array of
29
* double.
30
31
32
33
* @param[inout] pbase
34
* Couple of pointers to an array of integers and to an array of
35
* double to sort.
36
37
* @param[in] n
38
* The number of elements in the array.
39
40
41
#ifndef DOXYGEN_SHOULD_SKIP_THIS
42
static
size_t
intsortsize_if[2] = {
sizeof
spm_int_t
sizeof
double
43
#define INTSORTNAME d_spmIntFltSortAsc
44
#define INTSORTSIZE(x) (intsortsize_if[x])
45
#define INTSORTNTAB 2
46
#define INTSORTSWAP(p,q) do { \
47
spm_int_t t; \
48
long disp_p = (((spm_int_t*)p)-((spm_int_t*)base_ptr)); \
49
long disp_q = (((spm_int_t*)q)-((spm_int_t*)base_ptr)); \
50
double * floatptr = *(pbase+1); \
51
double f; \
52
/* swap integers */
53
t = *((spm_int_t *) (p)); \
54
*((spm_int_t *) (p)) = *((spm_int_t *) (q)); \
55
*((spm_int_t *) (q)) = t; \
56
/* swap corresponding values */
57
f = floatptr[disp_p]; \
58
floatptr[disp_p] = floatptr[disp_q]; \
59
floatptr[disp_q] = f; \
60
} while (0)
61
#define INTSORTCMP(p,q) (*((spm_int_t *) (p)) < *((spm_int_t *) (q)))
62
#include "integer_sort_mtypes.c"
63
#undef INTSORTNAME
64
#undef INTSORTSIZE
65
#undef INTSORTSWAP
66
#undef INTSORTCMP
67
#undef INTSORTNTAB
68
#endif
/* DOXYGEN_SHOULD_SKIP_THIS */
69
70
71
72
73
* @fn void d_spmIntIntFltSortAsc(void ** const pbase, const spm_int_t n)
74
75
76
77
* double.
78
79
80
81
82
83
* double to sort.
84
85
* @param[in] n
86
87
88
89
90
static
size_t
intsortsize_iif[3] = {
sizeof
spm_int_t
sizeof
spm_int_t
sizeof
(double) };
91
#define INTSORTNAME d_spmIntIntFltSortAsc
92
#define INTSORTSIZE(x) (intsortsize_iif[x])
93
#define INTSORTNTAB 3
94
95
spm_int_t t; \
96
97
98
spm_int_t * intptr = *(pbase+1); \
99
double * fltptr = *(pbase+2); \
100
double f; \
101
/* swap integers */
102
103
104
105
/* swap on second integer array */
106
t = intptr[disp_p]; \
107
intptr[disp_p] = intptr[disp_q]; \
108
intptr[disp_q] = t; \
109
110
f = fltptr[disp_p]; \
111
fltptr[disp_p] = fltptr[disp_q]; \
112
fltptr[disp_q] = f; \
113
} while (0)
114
115
116
117
118
* @brief TODO
119
120
121
122
123
124
* double to sort.
125
126
* @param[in] p
127
* TODO
128
129
* @param[in] q
130
* TODO
131
132
133
134
* @retval TODO
135
136
137
static
inline
int
138
intsortcmp_iif(
void
const
pbase,
139
spm_int_t
*p,
140
spm_int_t
*q )
141
142
spm_int_t
*int1ptr = pbase[0];
143
spm_int_t
*int2ptr = pbase[1];
144
return
( *p < *q ) || (( *p == *q ) && ( int2ptr[ p - int1ptr ] < int2ptr[ q - int1ptr ] ));
145
146
#define INTSORTCMP(p,q) intsortcmp_iif( pbase, (spm_int_t*)p, (spm_int_t*)q )
147
148
#undef INTSORTNAME
149
#undef INTSORTSIZE
150
#undef INTSORTSWAP
151
#undef INTSORTCMP
152
#undef INTSORTNTAB
153
#endif
spm_int_t
int spm_int_t
The main integer datatype used in spm arrays.
Definition
datatypes.h:70
build
src
d_spm_integer.c
Generated by
1.15.0
