SpM Handbook 1.3.0
Searching...
No Matches
z_spm_integer.c
Go to the documentation of this file.
1/**
2 *
3 * @file z_spm_integer.c
4 *
5 * SParse Matrix package integer sorting routines.
6 *
7 * @copyright 2016-2026 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
8 * Univ. Bordeaux. All rights reserved.
9 *
10 * @version 1.3.0
11 * @author Mathieu Faverge
12 * @author Pierre Ramet
13 * @author Tony Delarue
14 * @author Alycia Lisito
15 * @date 2024-07-09
16 *
17 * @generated from /builds/fpruvost/spm/src/z_spm_integer.c, normal z -> z, Fri Oct 23 13:05:00 2026
18 *
19 **/
20#include "common.h"
21
22/**
23 *******************************************************************************
24 *
25 * @fn void z_spmIntFltSortAsc(void ** const pbase, const spm_int_t n)
26 * @ingroup spm_dev_integer
27 * @brief Sort 2 arrays simultaneously, the first array is an array of
28 * spm_int_t and used as key for sorting. The second array is an array of
29 * spm_complex64_t.
30 *
31 *******************************************************************************
32 *
33 * @param[inout] pbase
34 * Couple of pointers to an array of integers and to an array of
35 * spm_complex64_t to sort.
36 *
37 * @param[in] n
38 * The number of elements in the array.
39 *
40 *******************************************************************************/
41#ifndef DOXYGEN_SHOULD_SKIP_THIS
42static size_t intsortsize_if[2] = { sizeof(spm_int_t), sizeof(spm_complex64_t) };
43#define INTSORTNAME z_spmIntFltSortAsc
44#define INTSORTSIZE(x) (intsortsize_if[x])
45#define INTSORTNTAB 2
46#define INTSORTSWAP(p,q) do { \
47 spm_int_t t; \
48 long disp_p = (((spm_int_t*)p)-((spm_int_t*)base_ptr)); \
49 long disp_q = (((spm_int_t*)q)-((spm_int_t*)base_ptr)); \
50 spm_complex64_t * floatptr = *(pbase+1); \
51 spm_complex64_t f; \
52 /* swap integers */ \
53 t = *((spm_int_t *) (p)); \
54 *((spm_int_t *) (p)) = *((spm_int_t *) (q)); \
55 *((spm_int_t *) (q)) = t; \
56 /* swap corresponding values */ \
57 f = floatptr[disp_p]; \
58 floatptr[disp_p] = floatptr[disp_q]; \
59 floatptr[disp_q] = f; \
60 } while (0)
61#define INTSORTCMP(p,q) (*((spm_int_t *) (p)) < *((spm_int_t *) (q)))
62#include "integer_sort_mtypes.c"
63#undef INTSORTNAME
64#undef INTSORTSIZE
65#undef INTSORTSWAP
66#undef INTSORTCMP
67#undef INTSORTNTAB
68#endif /* DOXYGEN_SHOULD_SKIP_THIS */
69
70/**
71 *******************************************************************************
72 *
73 * @fn void z_spmIntIntFltSortAsc(void ** const pbase, const spm_int_t n)
74 * @ingroup spm_dev_integer
75 * @brief Sort 2 arrays simultaneously, the first array is an array of
76 * spm_int_t and used as key for sorting. The second array is an array of
77 * spm_complex64_t.
78 *
79 *******************************************************************************
80 *
81 * @param[inout] pbase
82 * Couple of pointers to an array of integers and to an array of
83 * spm_complex64_t to sort.
84 *
85 * @param[in] n
86 * The number of elements in the array.
87 *
88 *******************************************************************************/
89#ifndef DOXYGEN_SHOULD_SKIP_THIS
90static size_t intsortsize_iif[3] = { sizeof(spm_int_t), sizeof(spm_int_t), sizeof(spm_complex64_t) };
91#define INTSORTNAME z_spmIntIntFltSortAsc
92#define INTSORTSIZE(x) (intsortsize_iif[x])
93#define INTSORTNTAB 3
94#define INTSORTSWAP(p,q) do { \
95 spm_int_t t; \
96 long disp_p = (((spm_int_t*)p)-((spm_int_t*)base_ptr)); \
97 long disp_q = (((spm_int_t*)q)-((spm_int_t*)base_ptr)); \
98 spm_int_t * intptr = *(pbase+1); \
99 spm_complex64_t * fltptr = *(pbase+2); \
100 spm_complex64_t f; \
101 /* swap integers */ \
102 t = *((spm_int_t *) (p)); \
103 *((spm_int_t *) (p)) = *((spm_int_t *) (q)); \
104 *((spm_int_t *) (q)) = t; \
105 /* swap on second integer array */ \
106 t = intptr[disp_p]; \
107 intptr[disp_p] = intptr[disp_q]; \
108 intptr[disp_q] = t; \
109 /* swap corresponding values */ \
110 f = fltptr[disp_p]; \
111 fltptr[disp_p] = fltptr[disp_q]; \
112 fltptr[disp_q] = f; \
113 } while (0)
114
115/**
116 *******************************************************************************
117 *
118 * @brief TODO
119 *
120 *******************************************************************************
121 *
122 * @param[inout] pbase
123 * Couple of pointers to an array of integers and to an array of
124 * spm_complex64_t to sort.
125 *
126 * @param[in] p
127 * TODO
128 *
129 * @param[in] q
130 * TODO
131 *
132 *******************************************************************************
133 *
134 * @retval TODO
135 *
136 *******************************************************************************/
137static inline int
138intsortcmp_iif( void ** const pbase,
139 spm_int_t *p,
140 spm_int_t *q )
141{
142 spm_int_t *int1ptr = pbase[0];
143 spm_int_t *int2ptr = pbase[1];
144 return ( *p < *q ) || (( *p == *q ) && ( int2ptr[ p - int1ptr ] < int2ptr[ q - int1ptr ] ));
145}
146#define INTSORTCMP(p,q) intsortcmp_iif( pbase, (spm_int_t*)p, (spm_int_t*)q )
147#include "integer_sort_mtypes.c"
148#undef INTSORTNAME
149#undef INTSORTSIZE
150#undef INTSORTSWAP
151#undef INTSORTCMP
152#undef INTSORTNTAB
153#endif /* DOXYGEN_SHOULD_SKIP_THIS */
double _Complex spm_complex64_t
The double complex arithmetic datatype.
Definition datatypes.h:162
int spm_int_t
The main integer datatype used in spm arrays.
Definition datatypes.h:70
