SpM Handbook 1.3.0
Searching...
No Matches
This group describes all the constants of the SpM package. More...
Macros
#define CBLAS_SADDR(_a_)
 Macro to get the address if need in the cblas calls.
#define SpmDistByColumn   (0x1 << 0)
 Distribution of the matrix storage.
#define SpmDistByRow   (0x1 << 1)
Typedefs
typedef enum spm_verbose_e spm_verbose_t
 Verbose modes.
typedef enum spm_coeftype_e spm_coeftype_t
 Arithmetic types.
typedef enum spm_fmttype_e spm_fmttype_t
 Sparse matrix format.
typedef enum spm_error_e spm_error_t
 Error codes.
typedef enum spm_driver_e spm_driver_t
 The list of matrix driver readers and generators.
typedef enum spm_rhstype_e spm_rhstype_t
 How to generate RHS.
Enumerations
enum  spm_verbose_e { SpmVerboseNot = 0 , SpmVerboseNo = 1 , SpmVerboseYes = 2 }
 Verbose modes. More...
enum  spm_coeftype_e {
  SpmPattern = 0 , SpmFloat = 2 , SpmDouble = 3 , SpmComplex32 = 4 ,
  SpmComplex64 = 5
 Arithmetic types. More...
enum  spm_fmttype_e { SpmCSC , SpmCSR , SpmIJV }
 Sparse matrix format. More...
enum  spm_error_e {
  SPM_SUCCESS = 0 , SPM_ERR_UNKNOWN = 1 , SPM_ERR_ALLOC = 2 , SPM_ERR_NOTIMPLEMENTED = 3 ,
  SPM_ERR_OUTOFMEMORY = 4 , SPM_ERR_THREAD = 5 , SPM_ERR_INTERNAL = 6 , SPM_ERR_BADPARAMETER = 7 ,
  SPM_ERR_FILE = 8 , SPM_ERR_INTEGER_TYPE = 9 , SPM_ERR_IO = 10 , SPM_ERR_MPI = 11
 Error codes. More...
enum  spm_driver_e {
  SpmDriverRSA , SpmDriverHB , SpmDriverIJV , SpmDriverMM ,
  SpmDriverLaplacian , SpmDriverXLaplacian , SpmDriverGraph , SpmDriverSPM
 The list of matrix driver readers and generators. More...
enum  spm_rhstype_e { SpmRhsOne , SpmRhsI , SpmRhsRndX , SpmRhsRndB }
 How to generate RHS. More...
Constants compatible with CBLAS & LAPACK & PLASMA
The naming and numbering of the following constants is consistent with:
enum  spm_layout_e { SpmRowMajor = 101 , SpmColMajor = 102 }
 Direction of the matrix storage. More...
enum  spm_trans_e { SpmNoTrans = 111 , SpmTrans = 112 , SpmConjTrans = 113 }
 Transpostion. More...
enum  spm_mtxtype_e { SpmGeneral = SpmNoTrans , SpmSymmetric = SpmTrans , SpmHermitian = SpmConjTrans }
 Matrix symmetry type property. More...
enum  spm_uplo_e { SpmUpper = 121 , SpmLower = 122 , SpmUpperLower = 123 }
 Upper/Lower part. More...
enum  spm_diag_e { SpmNonUnit = 131 , SpmUnit = 132 }
 Diagonal. More...
enum  spm_side_e { SpmLeft = 141 , SpmRight = 142 }
 Side of the operation. More...
enum  spm_normtype_e { SpmOneNorm = 171 , SpmFrobeniusNorm = 174 , SpmInfNorm = 175 , SpmMaxNorm = 177 }
 Norms. More...
enum  spm_dir_e { SpmDirForward = 391 , SpmDirBackward = 392 }
 Direction. More...
typedef enum spm_layout_e spm_layout_t
typedef enum spm_trans_e spm_trans_t
 Transpostion.
typedef enum spm_mtxtype_e spm_mtxtype_t
typedef enum spm_uplo_e spm_uplo_t
 Upper/Lower part.
typedef enum spm_diag_e spm_diag_t
 Diagonal.
typedef enum spm_side_e spm_side_t
typedef enum spm_normtype_e spm_normtype_t
 Norms.
typedef enum spm_dir_e spm_dir_t
 Direction.
Detailed Description
Macro Definition Documentation
◆ CBLAS_SADDR
#define CBLAS_SADDR ( _a_)
Value:
(&(_a_))
Parameters
[in]_a_The parameter for which the address is needed.
Definition at line 36 of file const.h.
Referenced by c_spmCheckAxb(), spm_cspmv(), spm_zspmv(), and z_spmCheckAxb().
◆ SpmDistByColumn
◆ SpmDistByRow
Typedef Documentation
◆ spm_coeftype_t
Arithmetic types.
This describes the different arithmetics that can be stored in a sparse matrix.
Remarks
The values start at 2 for compatibility purpose with PLASMA and DPLASMA libraries.
◆ spm_mtxtype_t
Remarks
Must match transposition.
Enumeration Type Documentation
◆ spm_verbose_e
Verbose modes.
Enumerator
SpmVerboseNot
Nothing
SpmVerboseNo
Default
SpmVerboseYes
Extended
Definition at line 48 of file const.h.
◆ spm_coeftype_e
Arithmetic types.
Remarks
Enumerator
SpmPattern
Pattern only, no values are stored
SpmFloat
Single precision real
SpmDouble
Double precision real
SpmComplex32
Single precision complex
SpmComplex64
Double precision complex
Definition at line 61 of file const.h.
◆ spm_fmttype_e
Enumerator
SpmCSC
Compressed sparse column
SpmCSR
Compressed sparse row
SpmIJV
Coordinates
Definition at line 72 of file const.h.
◆ spm_error_e
Error codes.
Enumerator
SPM_SUCCESS
No error
SPM_ERR_UNKNOWN
Unknown error
SPM_ERR_ALLOC
Allocation error
Not implemented feature
SPM_ERR_OUTOFMEMORY
Not enough memory
SPM_ERR_THREAD
Error with threads
SPM_ERR_INTERNAL
Internal error
Bad parameters given
SPM_ERR_FILE
Error in In/Out operations
Error with integer types
SPM_ERR_IO
Error with input/output
SPM_ERR_MPI
Error with MPI calls
Definition at line 81 of file const.h.
◆ spm_driver_e
Enumerator
SpmDriverRSA
RSA Fortran driver (deprecated)
SpmDriverHB
Harwell Boeing driver
SpmDriverIJV
IJV Coordinate driver
SpmDriverMM
Matrix Market C driver
SpmDriverLaplacian
3, 5, or 7 points Laplacian stencil generator
SpmDriverXLaplacian
15-points Laplacian stencil generator
SpmDriverGraph
Scotch Graph driver
SpmDriverSPM
SPM matrix driver
Definition at line 99 of file const.h.
◆ spm_rhstype_e
Definition at line 124 of file const.h.
◆ spm_layout_e
Enumerator
SpmRowMajor
Storage in row major order
SpmColMajor
Storage in column major order
Definition at line 146 of file const.h.
◆ spm_trans_e
Transpostion.
Enumerator
SpmNoTrans
Use A
SpmTrans
Use A^t
SpmConjTrans
Use conj(A^t)
Definition at line 154 of file const.h.
◆ spm_mtxtype_e
Remarks
Enumerator
SpmGeneral
The matrix is general
SpmSymmetric
The matrix is symmetric
SpmHermitian
The matrix is hermitian
Definition at line 164 of file const.h.
◆ spm_uplo_e
enum spm_uplo_e
Upper/Lower part.
Enumerator
SpmUpper
Use lower triangle of A
SpmLower
Use upper triangle of A
SpmUpperLower
Use the full A
Definition at line 173 of file const.h.
◆ spm_diag_e
enum spm_diag_e
Diagonal.
Enumerator
SpmNonUnit
Diagonal is non unitary
SpmUnit
Diagonal is unitary
Definition at line 182 of file const.h.
◆ spm_side_e
enum spm_side_e
Enumerator
SpmLeft
Apply operator on the left
SpmRight
Apply operator on the right
Definition at line 190 of file const.h.
◆ spm_normtype_e
Norms.
Enumerator
SpmOneNorm
One norm: max_j( sum_i( |a_{ij}| ) )
SpmFrobeniusNorm
Frobenius norm: sqrt( sum_{i,j} (a_{ij}^2) )
SpmInfNorm
Inifinite norm: max_i( sum_j( |a_{ij}| ) )
SpmMaxNorm
Max norm: max_{i,j}( | a_{ij} | )
Definition at line 198 of file const.h.
◆ spm_dir_e
enum spm_dir_e
Direction.
Enumerator
SpmDirForward
Forward direction
SpmDirBackward
Backward direction
Definition at line 208 of file const.h.
