SpM Handbook 1.3.0
Functions | |
| void | z_spmIntFltSortAsc (void **const pbase, const spm_int_t n) |
| Integer routines. | |
| void | z_spmIntIntFltSortAsc (void **const pbase, const spm_int_t n) |
| Sort 2 arrays simultaneously, the first array is an array of spm_int_t and used as key for sorting. The second array is an array of spm_complex64_t. | |
| void | c_spmIntFltSortAsc (void **const pbase, const spm_int_t n) |
| void | c_spmIntIntFltSortAsc (void **const pbase, const spm_int_t n) |
| Sort 2 arrays simultaneously, the first array is an array of spm_int_t and used as key for sorting. The second array is an array of spm_complex32_t. | |
| void | d_spmIntFltSortAsc (void **const pbase, const spm_int_t n) |
| void | d_spmIntIntFltSortAsc (void **const pbase, const spm_int_t n) |
| Sort 2 arrays simultaneously, the first array is an array of spm_int_t and used as key for sorting. The second array is an array of double. | |
| void | s_spmIntFltSortAsc (void **const pbase, const spm_int_t n) |
| void | s_spmIntIntFltSortAsc (void **const pbase, const spm_int_t n) |
| Sort 2 arrays simultaneously, the first array is an array of spm_int_t and used as key for sorting. The second array is an array of float. | |
| void | spmIntSort3Asc1 (void *const pbase, const spm_int_t n) |
| Sorts in ascending order array of element composed of three spm_int_t by ascending order. The first value is used as key. | |
| void | spmIntMSortSmallIntAsc (void **const pbase, const spm_int_t n) |
| Sort 2 arrays simultaneously, the first array is an array of spm_int_t and used as primary key for sorting. The second array is an other array of spm_int_t used as secondary key. | |
| void z_spmIntFltSortAsc | ( | void **const | pbase, |
| const spm_int_t | n ) |
Integer routines.
| [in,out] | pbase | Couple of pointers to an array of integers and to an array of spm_complex64_t to sort. |
| [in] | n | The number of elements in the array. |
Referenced by z_spmSortNoDof().
| void z_spmIntIntFltSortAsc | ( | void **const | pbase, |
| void c_spmIntFltSortAsc | ( | void **const | pbase, |
Integer routines.
| [in,out] | pbase | Couple of pointers to an array of integers and to an array of spm_complex32_t to sort. |
Referenced by c_spmSortNoDof().
| void c_spmIntIntFltSortAsc | ( | void **const | pbase, |
| void d_spmIntFltSortAsc | ( | void **const | pbase, |
Integer routines.
| [in,out] | pbase | Couple of pointers to an array of integers and to an array of double to sort. |
Referenced by d_spmSortNoDof().
| void d_spmIntIntFltSortAsc | ( | void **const | pbase, |
| void s_spmIntFltSortAsc | ( | void **const | pbase, |
Integer routines.
| [in,out] | pbase | Couple of pointers to an array of integers and to an array of float to sort. |
Referenced by s_spmSortNoDof().
| void s_spmIntIntFltSortAsc | ( | void **const | pbase, |
| void spmIntSort3Asc1 | ( | void *const | pbase, |
| [in,out] | pbase | Pointer to the array of triplet of integers to sort. |
| void spmIntMSortSmallIntAsc | ( | void **const | pbase, |
