spm_int_t p_spmMergeDuplicate(spmatrix_t *spm)
This routine merge the multiple entries in a sparse matrix by summing their values together.
void p_spmSort(spmatrix_t *spm)
This routine sorts the spm matrix.
int p_spmConvertIJV2CSR(spmatrix_t *spm)
convert a matrix in IJV format to a matrix in CSR format.
int p_spmConvertCSR2CSC(spmatrix_t *spm)
convert a matrix in CSR format to a matrix in CSC format.
int p_spmConvertCSR2IJV(spmatrix_t *spm)
convert a matrix in CSR format to a matrix in IJV format.
int p_spmConvertCSC2CSR(spmatrix_t *spm)
Conversion routines.
int p_spmConvertIJV2CSC(spmatrix_t *spm)
convert a matrix in IJV format to a matrix in CSC format.
int p_spmConvertCSC2IJV(spmatrix_t *spm)
Convert a matrix in CSC format to a matrix in IJV format.
void p_spmExpand(const spmatrix_t *spm_in, spmatrix_t *spm_out)
Expand a single dof sparse matrix to a multi-dofs sparse matrix.
void p_spmPrint(FILE *f, const spmatrix_t *spm)
Write a spm matrix in a file.
void p_spmPrintRHS(FILE *f, const spmatrix_t *spm, int nrhs, const void *x, spm_int_t ldx)
Write into a file the vectors associated to a spm.
struct spmatrix_s spmatrix_t
The sparse matrix data structure.
int spm_int_t
The main integer datatype used in spm arrays.
