SpM Handbook 1.3.0
Extra routines. More...
Files | |
| file | spm_update_compute_fields.c |
Functions | |
| void | z_spmSort (spmatrix_t *spm) |
| This routine sorts the spm matrix. | |
| spm_int_t | z_spmMergeDuplicate (spmatrix_t *spm) |
| This routine merge the multiple entries in a sparse matrix by summing their values together. | |
| void | c_spmSort (spmatrix_t *spm) |
| spm_int_t | c_spmMergeDuplicate (spmatrix_t *spm) |
| void | d_spmSort (spmatrix_t *spm) |
| spm_int_t | d_spmMergeDuplicate (spmatrix_t *spm) |
| void | s_spmSort (spmatrix_t *spm) |
| spm_int_t | s_spmMergeDuplicate (spmatrix_t *spm) |
| void | p_spmSort (spmatrix_t *spm) |
| spm_int_t | p_spmMergeDuplicate (spmatrix_t *spm) |
| static void | c_spmSortNoDof (spmatrix_t *spm) |
| This routine sorts the single dof spm matrix. | |
| static void | c_spmSortMultidof (spmatrix_t *spm) |
| This routine sorts the multiple dof spm matrix. | |
| static void | p_spmSortNoDof (spmatrix_t *spm) |
| static void | p_spmSortMultidof (spmatrix_t *spm) |
| static void | z_spmSortNoDof (spmatrix_t *spm) |
| static void | z_spmSortMultidof (spmatrix_t *spm) |
| static void | d_spmSortNoDof (spmatrix_t *spm) |
| static void | d_spmSortMultidof (spmatrix_t *spm) |
| static void | s_spmSortNoDof (spmatrix_t *spm) |
| static void | s_spmSortMultidof (spmatrix_t *spm) |
| spm_int_t * | spm_get_value_idx_by_col (const spmatrix_t *spm) |
| Create an array that represents the shift for each sub-element of the original multidof value array. | |
| spm_int_t * | spm_get_value_idx_by_elt (const spmatrix_t *spm) |
Extra routines.
| void z_spmSort | ( | spmatrix_t * | spm | ) |
For the CSC and CSR formats, the subarray of edges for each vertex are sorted. For the IJV format, the edges are storted first by column indexes, and then by row indexes. To perform a sort first by row, second by column, please swap the colptr and rowptr of the structure before calling the subroutine.
| [in,out] | spm | On entry, the pointer to the sparse matrix structure. On exit, the same sparse matrix with subarrays of edges sorted by ascending order. |
Definition at line 303 of file z_spm_sort.c.
References spmatrix_s::colptr, spmatrix_s::dof, spmatrix_s::flttype, spmatrix_s::fmttype, spmatrix_s::rowptr, spm_get_distribution(), spm_getandset_glob2loc(), SpmDistByRow, SpmIJV, SpmPattern, z_spmSortMultidof(), and z_spmSortNoDof().
Referenced by spmSort(), and z_spmConvertIJV2CSC().
| spm_int_t z_spmMergeDuplicate | ( | spmatrix_t * | spm | ) |
The sparse matrix needs to be sorted first (see z_spmSort()). In distributed, only local entries are merged together.
| [in,out] | spm | On entry, the pointer to the sparse matrix structure. On exit, the reducton of the input sparse matrix where multiple occurences of a same element are summed up together. |
Definition at line 46 of file z_spm_mergeduplicate.c.
References spmatrix_s::baseval, spmatrix_s::colptr, spmatrix_s::dof, spmatrix_s::dofs, spmatrix_s::fmttype, spmatrix_s::loc2glob, spmatrix_s::n, spmatrix_s::nnz, spmatrix_s::nnzexp, spmatrix_s::replicated, spmatrix_s::rowptr, SPM_ERR_BADPARAMETER, SpmCSC, SpmCSR, and spmatrix_s::values.
Referenced by spmMergeDuplicate().
| void c_spmSort | ( | spmatrix_t * | spm | ) |
Definition at line 303 of file c_spm_sort.c.
References c_spmSortMultidof(), c_spmSortNoDof(), spmatrix_s::colptr, spmatrix_s::dof, spmatrix_s::flttype, spmatrix_s::fmttype, spmatrix_s::rowptr, spm_get_distribution(), spm_getandset_glob2loc(), SpmDistByRow, SpmIJV, and SpmPattern.
Referenced by c_spmConvertIJV2CSC(), and spmSort().
| spm_int_t c_spmMergeDuplicate | ( | spmatrix_t * | spm | ) |
The sparse matrix needs to be sorted first (see c_spmSort()). In distributed, only local entries are merged together.
Definition at line 46 of file c_spm_mergeduplicate.c.
| void d_spmSort | ( | spmatrix_t * | spm | ) |
Definition at line 303 of file d_spm_sort.c.
References spmatrix_s::colptr, d_spmSortMultidof(), d_spmSortNoDof(), spmatrix_s::dof, spmatrix_s::flttype, spmatrix_s::fmttype, spmatrix_s::rowptr, spm_get_distribution(), spm_getandset_glob2loc(), SpmDistByRow, SpmIJV, and SpmPattern.
Referenced by d_spmConvertIJV2CSC(), and spmSort().
| spm_int_t d_spmMergeDuplicate | ( | spmatrix_t * | spm | ) |
The sparse matrix needs to be sorted first (see d_spmSort()). In distributed, only local entries are merged together.
Definition at line 46 of file d_spm_mergeduplicate.c.
| void s_spmSort | ( | spmatrix_t * | spm | ) |
Definition at line 303 of file s_spm_sort.c.
References spmatrix_s::colptr, spmatrix_s::dof, spmatrix_s::flttype, spmatrix_s::fmttype, spmatrix_s::rowptr, s_spmSortMultidof(), s_spmSortNoDof(), spm_get_distribution(), spm_getandset_glob2loc(), SpmDistByRow, SpmIJV, and SpmPattern.
Referenced by s_spmConvertIJV2CSC(), and spmSort().
| spm_int_t s_spmMergeDuplicate | ( | spmatrix_t * | spm | ) |
The sparse matrix needs to be sorted first (see s_spmSort()). In distributed, only local entries are merged together.
Definition at line 46 of file s_spm_mergeduplicate.c.
| void p_spmSort | ( | spmatrix_t * | spm | ) |
Definition at line 303 of file p_spm_sort.c.
References spmatrix_s::colptr, spmatrix_s::dof, spmatrix_s::flttype, spmatrix_s::fmttype, p_spmSortMultidof(), p_spmSortNoDof(), spmatrix_s::rowptr, spm_get_distribution(), spm_getandset_glob2loc(), SpmDistByRow, SpmIJV, and SpmPattern.
Referenced by p_spmConvertIJV2CSC(), and spmSort().
| spm_int_t p_spmMergeDuplicate | ( | spmatrix_t * | spm | ) |
The sparse matrix needs to be sorted first (see p_spmSort()). In distributed, only local entries are merged together.
Definition at line 46 of file p_spm_mergeduplicate.c.
static |
Definition at line 44 of file c_spm_sort.c.
References c_spmIntFltSortAsc(), c_spmIntIntFltSortAsc(), spmatrix_s::colptr, spmatrix_s::fmttype, spmatrix_s::n, spmatrix_s::nnz, spmatrix_s::rowptr, SpmCSC, SpmCSR, SpmIJV, and spmatrix_s::values.
Referenced by c_spmSort().
static |
For the CSC and CSR formats, the subarray of edges for each vertex are sorted. For the IJV format, the edges are sorted first by column indexes, and then by row indexes. To perform a sort first by row, second by column, please swap the colptr and rowptr of the structure before calling the subroutine. This routine is used for multidof matrices. It's way less efficient than the single dof one.
Definition at line 237 of file c_spm_sort.c.
References c_spm_sort_multidof_csx_values(), c_spm_sort_multidof_ijv_values(), spmatrix_s::dof, spmatrix_s::flttype, spmatrix_s::fmttype, spmatrix_s::nnzexp, spm_get_value_idx_by_elt(), SpmIJV, spmSort(), and spmatrix_s::values.
static |
Definition at line 44 of file p_spm_sort.c.
References spmatrix_s::colptr, spmatrix_s::fmttype, spmatrix_s::n, spmatrix_s::nnz, spmatrix_s::rowptr, SpmCSC, SpmCSR, SpmIJV, and spmatrix_s::values.
Referenced by p_spmSort().
static |
Definition at line 237 of file p_spm_sort.c.
References spmatrix_s::dof, spmatrix_s::flttype, spmatrix_s::fmttype, spmatrix_s::nnzexp, p_spm_sort_multidof_csx_values(), p_spm_sort_multidof_ijv_values(), spm_get_value_idx_by_elt(), SpmIJV, spmSort(), and spmatrix_s::values.
static |
Definition at line 44 of file z_spm_sort.c.
References spmatrix_s::colptr, spmatrix_s::fmttype, spmatrix_s::n, spmatrix_s::nnz, spmatrix_s::rowptr, SpmCSC, SpmCSR, SpmIJV, spmatrix_s::values, z_spmIntFltSortAsc(), and z_spmIntIntFltSortAsc().
Referenced by z_spmSort().
static |
Definition at line 237 of file z_spm_sort.c.
References spmatrix_s::dof, spmatrix_s::flttype, spmatrix_s::fmttype, spmatrix_s::nnzexp, spm_get_value_idx_by_elt(), SpmIJV, spmSort(), spmatrix_s::values, z_spm_sort_multidof_csx_values(), and z_spm_sort_multidof_ijv_values().
static |
Definition at line 44 of file d_spm_sort.c.
References spmatrix_s::colptr, d_spmIntFltSortAsc(), d_spmIntIntFltSortAsc(), spmatrix_s::fmttype, spmatrix_s::n, spmatrix_s::nnz, spmatrix_s::rowptr, SpmCSC, SpmCSR, SpmIJV, and spmatrix_s::values.
Referenced by d_spmSort().
static |
Definition at line 237 of file d_spm_sort.c.
References d_spm_sort_multidof_csx_values(), d_spm_sort_multidof_ijv_values(), spmatrix_s::dof, spmatrix_s::flttype, spmatrix_s::fmttype, spmatrix_s::nnzexp, spm_get_value_idx_by_elt(), SpmIJV, spmSort(), and spmatrix_s::values.
static |
Definition at line 44 of file s_spm_sort.c.
References spmatrix_s::colptr, spmatrix_s::fmttype, spmatrix_s::n, spmatrix_s::nnz, spmatrix_s::rowptr, s_spmIntFltSortAsc(), s_spmIntIntFltSortAsc(), SpmCSC, SpmCSR, SpmIJV, and spmatrix_s::values.
Referenced by s_spmSort().
static |
Definition at line 237 of file s_spm_sort.c.
References spmatrix_s::dof, spmatrix_s::flttype, spmatrix_s::fmttype, spmatrix_s::nnzexp, s_spm_sort_multidof_csx_values(), s_spm_sort_multidof_ijv_values(), spm_get_value_idx_by_elt(), SpmIJV, spmSort(), and spmatrix_s::values.
| spm_int_t * spm_get_value_idx_by_col | ( | const spmatrix_t * | spm | ) |
| [in] | spm | The sparse matrix structure. |
Definition at line 2153 of file spm.c.
References spmatrix_s::baseval, spmatrix_s::colptr, spmatrix_s::dof, spmatrix_s::dofs, spmatrix_s::fmttype, spmatrix_s::loc2glob, spmatrix_s::n, spmatrix_s::nnzexp, spmatrix_s::replicated, spmatrix_s::rowptr, SpmCSC, SpmCSR, and SpmIJV.
| spm_int_t * spm_get_value_idx_by_elt | ( | const spmatrix_t * | spm | ) |
Definition at line 2224 of file spm.c.
References spmatrix_s::baseval, spmatrix_s::colptr, spmatrix_s::dof, spmatrix_s::dofs, spmatrix_s::fmttype, spmatrix_s::loc2glob, spmatrix_s::n, spmatrix_s::nnz, spmatrix_s::nnzexp, spmatrix_s::replicated, spmatrix_s::rowptr, SpmCSC, SpmCSR, and SpmIJV.
Referenced by c_spmConvertCSR2CSC_gen(), c_spmSortMultidof(), d_spmConvertCSR2CSC_gen(), d_spmSortMultidof(), p_spmConvertCSR2CSC_gen(), p_spmSortMultidof(), s_spmConvertCSR2CSC_gen(), s_spmSortMultidof(), spm_scatter_csx_local_generic(), z_spmConvertCSR2CSC_gen(), and z_spmSortMultidof().
