SpM Handbook 1.3.0
Searching...
No Matches
spm_integers.c
Go to the documentation of this file.
1/**
2 *
3 * @file spm_integers.c
4 *
5 * SParse Matrix package integers array management routines.
6 *
7 * @copyright 2016-2026 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
8 * Univ. Bordeaux. All rights reserved.
9 *
10 * @version 1.3.0
11 * @author Francois Pellegrini
12 * @author Xavier Lacoste
13 * @author Pierre Ramet
14 * @author Mathieu Faverge
15 * @author Matias Hastaran
16 * @author Tony Delarue
17 * @author Alycia Lisito
18 * @date 2024-07-09
19 *
20 **/
21#include "common.h"
22
23/**
24 *******************************************************************************
25 *
26 * @ingroup spm
27 *
28 * @brief Convert integer array to spm_int_t format.
29 *
30 *******************************************************************************
31 *
32 * @param[in] n
33 * The number of elements in the array.
34 *
35 * @param[in] input
36 * The input int array.
37 *
38 * @param[inout] output
39 * The output spm_int_t array.
40 *
41 *******************************************************************************/
42void
43spmIntConvert( spm_int_t n, const int *input, spm_int_t *output )
44{
45 if (sizeof(spm_int_t) != sizeof(int)) {
46 spm_int_t *tmpo;
47 const int *tmpi;
48 int i;
49
50 tmpi = input;
51 tmpo = output;
52 for(i=0; i<n; i++, tmpi++, tmpo++) {
53 *tmpo = (spm_int_t)(*tmpi);
54 }
55 }
56 else {
57 memcpy( output, input, n * sizeof(int) );
58 }
59}
60
61/**
62 *******************************************************************************
63 *
64 * @fn void spmIntSort1Asc1(void * const pbase, const spm_int_t n);
65 * @ingroup spm_dev_integer
66 *
67 * Sorts in ascending order array of element composed of one single
68 * spm_int_t with a single key value.
69 *
70 *******************************************************************************
71 *
72 * @param[inout] pbase
73 * Pointer to the array of integers to sort.
74 *
75 * @param[in] n
76 * The number of elements in the array.
77 *
78 *******************************************************************************/
79#ifndef DOXYGEN_SHOULD_SKIP_THIS
80#define INTSORTNAME spmIntSort1Asc1
81#define INTSORTSIZE (sizeof (spm_int_t))
82#define INTSORTSWAP(p,q) do { \
83 spm_int_t t; \
84 t = *((spm_int_t *) (p)); \
85 *((spm_int_t *) (p)) = *((spm_int_t *) (q)); \
86 *((spm_int_t *) (q)) = t; \
87 } while (0)
88#define INTSORTCMP(p,q) (*((spm_int_t *) (p)) < *((spm_int_t *) (q)))
89#include "integer_sort.c"
90#undef INTSORTNAME
91#undef INTSORTSIZE
92#undef INTSORTSWAP
93#undef INTSORTCMP
94#endif /* DOXYGEN_SHOULD_SKIP_THIS */
95
96/**
97 *******************************************************************************
98 *
99 * @fn void spmIntSort2Asc1(void * const pbase, const spm_int_t n);
100 * @ingroup spm_dev_integer
101 *
102 * Sorts in ascending order array of element composed of two
103 * spm_int_t by ascending order. The first value is used as key.
104 *
105 *******************************************************************************
106 *
107 * @param[inout] pbase
108 * Pointer to the array of couple of integers to sort.
109 *
110 * @param[in] n
111 * The number of elements in the array.
112 *
113 *******************************************************************************/
114#ifndef DOXYGEN_SHOULD_SKIP_THIS
115#define INTSORTNAME spmIntSort2Asc1
116#define INTSORTSIZE (2 * sizeof (spm_int_t))
117#define INTSORTSWAP(p,q) do { \
118 spm_int_t t, u; \
119 t = *((spm_int_t *) (p)); \
120 u = *((spm_int_t *) (p) + 1); \
121 *((spm_int_t *) (p)) = *((spm_int_t *) (q)); \
122 *((spm_int_t *) (p) + 1) = *((spm_int_t *) (q) + 1); \
123 *((spm_int_t *) (q)) = t; \
124 *((spm_int_t *) (q) + 1) = u; \
125 } while (0)
126#define INTSORTCMP(p,q) (*((spm_int_t *) (p)) < *((spm_int_t *) (q)))
127#include "integer_sort.c"
128#undef INTSORTNAME
129#undef INTSORTSIZE
130#undef INTSORTSWAP
131#undef INTSORTCMP
132#endif /* DOXYGEN_SHOULD_SKIP_THIS */
133
134/**
135 *******************************************************************************
136 *
137 * @fn void spmIntSort3Asc1(void * const pbase, const spm_int_t n);
138 * @ingroup spm_dev_integer
139 *
140 * @brief Sorts in ascending order array of element composed of three
141 * spm_int_t by ascending order. The first value is used as key.
142 *
143 *******************************************************************************
144 *
145 * @param[inout] pbase
146 * Pointer to the array of triplet of integers to sort.
147 *
148 * @param[in] n
149 * The number of elements in the array.
150 *
151 ********************************************************************************/
152/* Declared here for now, because unused */
153void spmIntSort3Asc1(void *const pbase, const spm_int_t n);
154
155#ifndef DOXYGEN_SHOULD_SKIP_THIS
156#define INTSORTNAME spmIntSort3Asc1
157#define INTSORTSIZE (3 * sizeof (spm_int_t))
158#define INTSORTSWAP(p,q) do { \
159 spm_int_t t, u, v; \
160 t = *((spm_int_t *) (p)); \
161 u = *((spm_int_t *) (p) + 1); \
162 v = *((spm_int_t *) (p) + 2); \
163 *((spm_int_t *) (p)) = *((spm_int_t *) (q)); \
164 *((spm_int_t *) (p) + 1) = *((spm_int_t *) (q) + 1); \
165 *((spm_int_t *) (p) + 2) = *((spm_int_t *) (q) + 2); \
166 *((spm_int_t *) (q)) = t; \
167 *((spm_int_t *) (q) + 1) = u; \
168 *((spm_int_t *) (q) + 2) = v; \
169 } while (0)
170#define INTSORTCMP(p,q) (*((spm_int_t *) (p)) < *((spm_int_t *) (q)))
171#include "integer_sort.c"
172#undef INTSORTNAME
173#undef INTSORTSIZE
174#undef INTSORTSWAP
175#undef INTSORTCMP
176#endif /* DOXYGEN_SHOULD_SKIP_THIS */
177
178/**
179 *******************************************************************************
180 *
181 * @fn void spmIntSort2Asc2(void * const pbase, const spm_int_t n);
182 * @ingroup spm_dev_integer
183 * @brief Sorts in ascending order array of element composed of two
184 * spm_int_t by ascending order. Both values are used as key.
185 *
186 *******************************************************************************
187 *
188 * @param[inout] pbase
189 * Pointer to the array of couple of integers to sort.
190 *
191 * @param[in] n
192 * The number of elements in the array.
193 *
194 ********************************************************************************/
195#ifndef DOXYGEN_SHOULD_SKIP_THIS
196#define INTSORTNAME spmIntSort2Asc2
197#define INTSORTSIZE (2 * sizeof (spm_int_t))
198#define INTSORTSWAP(p,q) do { \
199 spm_int_t t, u; \
200 t = *((spm_int_t *) (p)); \
201 u = *((spm_int_t *) (p) + 1); \
202 *((spm_int_t *) (p)) = *((spm_int_t *) (q)); \
203 *((spm_int_t *) (p) + 1) = *((spm_int_t *) (q) + 1); \
204 *((spm_int_t *) (q)) = t; \
205 *((spm_int_t *) (q) + 1) = u; \
206 } while (0)
207#define INTSORTCMP(p,q) ((*((spm_int_t *) (p)) < *((spm_int_t *) (q))) || ((*((spm_int_t *) (p)) == *((spm_int_t *) (q))) && (*((spm_int_t *) (p) + 1) < *((spm_int_t *) (q) + 1))))
208#include "integer_sort.c"
209#undef INTSORTNAME
210#undef INTSORTSIZE
211#undef INTSORTSWAP
212#undef INTSORTCMP
213#endif /* DOXYGEN_SHOULD_SKIP_THIS */
214
215/**
216 *******************************************************************************
217 *
218 * @fn void spmIntMSortIntAsc(void ** const pbase, const spm_int_t n);
219 * @ingroup spm_dev_integer
220 *
221 * @brief Sort 2 arrays simultaneously, the first array is an array of
222 * spm_int_t and used as primary key for sorting. The second array is an
223 * other array of spm_int_t used as secondary key.
224 *
225 *******************************************************************************
226 *
227 * @param[inout] pbase
228 * Array of pointers to the arrays of integers to sort.
229 *
230 * @param[in] n
231 * The number of elements in the array.
232 *
233 ********************************************************************************/
234#ifndef DOXYGEN_SHOULD_SKIP_THIS
235#define INTSORTNAME spmIntMSortIntAsc
236#define INTSORTSIZE(x) (sizeof (spm_int_t))
237#define INTSORTNTAB 2
238#define INTSORTSWAP(p,q) do { \
239 spm_int_t t; \
240 long disp_p = (((spm_int_t*)p)-((spm_int_t*)base_ptr)); \
241 long disp_q = (((spm_int_t*)q)-((spm_int_t*)base_ptr)); \
242 spm_int_t * int2ptr = *(pbase+1); \
243 /* swap integers */ \
244 t = *((spm_int_t *) (p)); \
245 *((spm_int_t *) (p)) = *((spm_int_t *) (q)); \
246 *((spm_int_t *) (q)) = t; \
247 /* swap on second integer array */ \
248 t = int2ptr[disp_p]; \
249 int2ptr[disp_p] = int2ptr[disp_q]; \
250 int2ptr[disp_q] = t; \
251 } while (0)
252#define INTSORTCMP(p,q) ((*((spm_int_t *) (p)) < *((spm_int_t *) (q))) || \
253 ((*((spm_int_t *) (p)) == *((spm_int_t *) (q))) && \
254 ((( spm_int_t *)(*(pbase+1)))[(((spm_int_t*)p)-((spm_int_t*)base_ptr))] < \
255 (( spm_int_t *)(*(pbase+1)))[(((spm_int_t*)q)-((spm_int_t*)base_ptr))])))
256#include "integer_sort_mtypes.c"
257#undef INTSORTNAME
258#undef INTSORTSIZE
259#undef INTSORTSWAP
260#undef INTSORTCMP
261#undef INTSORTNTAB
262#endif /* DOXYGEN_SHOULD_SKIP_THIS */
263
264/**
265 *******************************************************************************
266 *
267 * @fn void spmIntMSortSmallIntAsc(void **const pbase, const spm_int_t n);
268 * @ingroup spm_dev_integer
269 * @brief Sort 2 arrays simultaneously, the first array is an array of
270 * spm_int_t and used as primary key for sorting. The second array is an
271 * other array of spm_int_t used as secondary key.
272 *
273 *******************************************************************************
274 *
275 * @param[inout] pbase
276 * Array of pointers to the arrays of integers to sort.
277 *
278 * @param[in] n
279 * The number of elements in the array.
280 *
281 ********************************************************************************/
282/* Declared here for now, because unused */
283void spmIntMSortSmallIntAsc(void ** const pbase, const spm_int_t n);
284
285#ifndef DOXYGEN_SHOULD_SKIP_THIS
286#define INTSORTNAME spmIntMSortSmallIntAsc
287#define INTSORTSIZE(x) (sizeof (int))
288#define INTSORTNTAB 2
289#define INTSORTSWAP(p,q) do { \
290 int t; \
291 long disp_p = (((int*)p)-((int*)base_ptr)); \
292 long disp_q = (((int*)q)-((int*)base_ptr)); \
293 int * int2ptr = *(pbase+1); \
294 /* swap integers */ \
295 t = *((int *) (p)); \
296 *((int *) (p)) = *((int *) (q)); \
297 *((int *) (q)) = t; \
298 /* swap on secont integer array */ \
299 t = int2ptr[disp_p]; \
300 int2ptr[disp_p] = int2ptr[disp_q]; \
301 int2ptr[disp_q] = t; \
302 } while (0)
303#define INTSORTCMP(p,q) ((*((int *) (p)) < *((int *) (q))) || \
304 ((*((int *) (p)) == *((int *) (q))) && \
305 ((( int *)(*(pbase+1)))[(((int*)p)-((int*)base_ptr))] < \
306 (( int *)(*(pbase+1)))[(((int*)q)-((int*)base_ptr))])))
307#include "integer_sort_mtypes.c"
308#undef INTSORTNAME
309#undef INTSORTSIZE
310#undef INTSORTSWAP
311#undef INTSORTCMP
312#undef INTSORTNTAB
313#endif /* DOXYGEN_SHOULD_SKIP_THIS */
Sort 2 arrays simultaneously, the first array is an array of spm_int_t and used as primary key for so...
Sorts in ascending order array of element composed of three spm_int_t by ascending order....
void spmIntConvert(spm_int_t n, const int *input, spm_int_t *output)
int spm_int_t
The main integer datatype used in spm arrays.
Definition datatypes.h:70
