SpM Handbook
1.2.4
Searching...
No Matches
c_spm_scal.c
Go to the documentation of this file.
1
2
* @file c_spm_scal.c
3
4
* SParse Matrix package scaling routine.
5
6
* @copyright 2016-2024 Bordeaux INP, CNRS (LaBRI UMR 5800), Inria,
7
* Univ. Bordeaux. All rights reserved.
8
9
* @version 1.2.4
10
* @author Mathieu Faverge
11
* @author Pierre Ramet
12
* @author Matias Hastaran
13
* @author Tony Delarue
14
* @author Alycia Lisito
15
* @author Gregoire Pichon
16
* @date 2024-05-29
17
* @generated from /builds/2mk6rsew/0/fpruvost/spm/src/z_spm_scal.c, normal z -> c, Fri Nov 29 11:34:28 2024
18
19
20
#include "common.h"
21
22
23
24
25
* @ingroup spm_dev_scal
26
27
* @brief Scal the spm: A = alpha * A
28
29
30
31
* @param[in] alpha
32
* The scaling parameter.
33
34
* @param[inout] spm
35
* The spm which needs to be scaled.
36
37
38
void
39
c_spmScal
const
float
alpha,
40
spmatrix_t
*spm )
41
42
spm_int_t
nnzexp, i;
43
spm_complex32_t
*values;
44
45
nnzexp = spm->
nnzexp
46
values = spm->
values
47
48
for
(i=0; i<nnzexp; i++){
49
values[i] *= alpha;
50
51
spm_complex32_t
float _Complex spm_complex32_t
Definition
datatypes.h:161
c_spmScal
void c_spmScal(const float alpha, spmatrix_t *spm)
Scal the spm: A = alpha * A.
Definition
c_spm_scal.c:39
spmatrix_s::values
void * values
Definition
spm.h:92
spmatrix_s::nnzexp
spm_int_t nnzexp
Definition
spm.h:80
spm_int_t
int spm_int_t
The main integer datatype used in spm arrays.
Definition
datatypes.h:70
spmatrix_s
The sparse matrix data structure.
Definition
spm.h:64
build
src
c_spm_scal.c
Generated by
1.9.8
