SpM Handbook 1.3.0
Searching...
No Matches
datatypes.h File Reference
#include <inttypes.h>
#include "spm/config.h"
Go to the source code of this file.
Macros
#define SPM_MPI_INT   MPI_INT
 The MPI type associated to spm_int_t.
#define SPM_INT_MAX   INT_MAX
 The maximum spm_int_t value.
Typedefs
typedef int spm_int_t
 The main integer datatype used in spm arrays.
typedef unsigned int spm_uint_t
 The main unsigned integer datatype used in spm arrays.
typedef double spm_fixdbl_t
 Double datatype that is not converted through precision generator functions.
typedef float _Complex spm_complex32_t
 The real complex arithmetic datatype.
typedef double _Complex spm_complex64_t
 The double complex arithmetic datatype.
Functions
static spm_int_t spm_imin (spm_int_t a, spm_int_t b)
 Internal function to compute min(a,b).
static spm_int_t spm_imax (spm_int_t a, spm_int_t b)
 Internal function to compute max(a,b).
static spm_int_t spm_iceil (spm_int_t a, spm_int_t b)
 Internal function to compute ceil(a,b).
static size_t spm_size_of (spm_coeftype_t type)
Detailed Description
Definitions of the datatypes used in SPM
Version
1.3.0
Author
Mathieu Faverge
Pierre Ramet
Tony Delarue
Alycia Lisito
Date
2024-07-09
Definition in file datatypes.h.
Typedef Documentation
◆ spm_fixdbl_t
Definition at line 150 of file datatypes.h.
Function Documentation
◆ spm_imin()
◆ spm_imax()
◆ spm_iceil()
spm_int_t spm_iceil ( spm_int_t a,
spm_int_t b )
static
Parameters
[in]a
[in]b
Returns
ceil( a, b )
Definition at line 141 of file datatypes.h.
◆ spm_size_of()
size_t spm_size_of ( spm_coeftype_t type)
static
These declarations will not clash with what C++ provides because the names in C++ are name-mangled.
Parameters
[in]typeTODO
Return values
TODO
Definition at line 209 of file datatypes.h.
References SpmComplex32, SpmComplex64, SpmDouble, SpmFloat, and SpmPattern.
Referenced by spm_load_local(), spm_redist_extract_local(), spm_redist_post_recv(), spm_redist_send(), spm_redist_send_loop_csx(), spm_redist_send_loop_ijv(), spm_scatter_csx_local_continuous(), spm_scatter_csx_local_generic(), spm_scatter_csx_send_continuous(), spm_scatter_csx_send_generic(), spm_scatter_ijv_local(), spm_scatter_ijv_remote(), spm_scatter_ijv_send(), spm_symm_local_add(), spmAlloc(), and spmCopy().
