SpM Handbook 1.2.4
Searching...
No Matches
d_spm_2dense.c File Reference
#include "common.h"
Go to the source code of this file.
Functions
static void d_spm_2dense_elt_sym_diag (spm_int_t row, spm_int_t dofi, spm_dconj_fct_t conjfct, const double *valptr, double *A, spm_int_t lda)
 Convert to dense a diagonal element within a symmetric/symmetric matrix with column/row major storage.
static void d_spm_2dense_elt_gen_col (const spm_int_t row, const spm_int_t dofi, const spm_int_t col, const spm_int_t dofj, const spm_dconj_fct_t conjfct, const double *valptr, double *A, const spm_int_t lda)
 Convert to dense a general element matrix with column major storage.
static void d_spm_2dense_elt_gen_row (const spm_int_t row, const spm_int_t dofi, const spm_int_t col, const spm_int_t dofj, const spm_dconj_fct_t conjfct, const double *valptr, double *A, const spm_int_t lda)
 Convert to dense a general element matrix with row major storage.
static void d_spm_2dense_elt_gen (const spm_layout_t layout, const spm_int_t row, const spm_int_t dofi, const spm_int_t col, const spm_int_t dofj, const spm_dconj_fct_t conjfct, const double *valptr, double *A, const spm_int_t lda)
 Convert to dense a general element matrix.
static void d_spm_2dense_elt_sym_offd (const spm_layout_t layout, const spm_int_t row, const spm_int_t dofi, const spm_int_t col, const spm_int_t dofj, const spm_dconj_fct_t conjfct, const double *valptr, double *A, const spm_int_t lda)
 Convert to dense an off-diagonal element matrix in the symmetric/symmetric case.
static void d_spm_2dense_elt (const spm_mtxtype_t mtxtype, const spm_layout_t layout, const spm_int_t row, const spm_int_t dofi, const spm_int_t col, const spm_int_t dofj, const double *valptr, double *A, const spm_int_t lda)
 Convert to dense an element matrix.
static void d_spmCSC2dense (const spmatrix_t *spm, double *A)
 Convert a CSC matrix into a dense matrix.
static void d_spmCSR2dense (const spmatrix_t *spm, double *A)
 Convert a CSR matrix into a dense matrix.
static void d_spmIJV2dense (const spmatrix_t *spm, double *A)
 Convert a IJV matrix into a dense matrix.
void d_spm2dense (const spmatrix_t *spm, double *A)
 Convert a sparse matrix into a dense matrix.
void d_spmDensePrint (FILE *f, spm_int_t m, spm_int_t n, const double *A, spm_int_t lda)
 Print a dense matrix to the given file.
Detailed Description
SParse Matrix package conversion to dense routine.
Version
1.2.4
Author
Mathieu Faverge
Alban Bellot
Matias Hastaran
Tony Delarue
Alycia Lisito
Date
2024-06-25
Generated arithmetic file from /builds/2mk6rsew/0/fpruvost/spm/src/z_spm_2dense.c, normal z -> d, Fri Nov 29 11:34:29 2024
Definition in file d_spm_2dense.c.
