SpM Handbook 1.3.0
#include "common.h"#include <lapacke.h>#include <cblas.h>Go to the source code of this file.
Functions | |
| int | spm_dspmm (spm_side_t side, spm_trans_t transA, spm_trans_t transB, spm_int_t K, double alpha, const spmatrix_t *A, const double *B, spm_int_t ldb, double beta, double *C, spm_int_t ldc) |
| Compute a matrix-matrix product. | |
| int | spm_dspmv (spm_trans_t trans, double alpha, const spmatrix_t *A, const double *x, spm_int_t incx, double beta, double *y, spm_int_t incy) |
| compute the matrix-vector product: | |
| #define | LAPACKE_dlascl_work(_dir_, _uplo_, _kl_, _ku_, _cfrom_, _cto_, _m_, _n_, _A_, _lda_) |
| Alias if Lapacke zlscl is not available. | |
| typedef struct __spm_dmatvec_s | __spm_dmatvec_t |
| Typedef associated to structure. | |
| typedef double(* | __conj_fct_t) (double) |
| Typedef to define the op function applied to the element (id or ). | |
| typedef int(* | __loop_fct_t) (const __spm_dmatvec_t *) |
| Typedef to the main loop function performing the matvec operation. | |
| static double | __fct_id (double val) |
| Identity function. | |
| static void | d_spmm_build_Ctmp (int nrhs, const spmatrix_t *spm, const double *Cloc, spm_int_t ldcl, double **Cglb, spm_int_t *ldcg) |
| Build a global C RHS, set to 0 for remote datas. | |
| static void | d_spmm_build_Btmp (int nrhs, const spmatrix_t *spm, const double *Bloc, spm_int_t ldbl, double **Bglb, spm_int_t *ldbg) |
| Build a global B vector by gathering datas from all nodes. | |
SParse Matrix package matrix-vector multiplication routines.
Definition in file d_spm_matrixvector.c.
| #define LAPACKE_dlascl_work | ( | _dir_, | |
| _uplo_, | |||
| _kl_, | |||
| _ku_, | |||
| _cfrom_, | |||
| _cto_, | |||
| _m_, | |||
| _n_, | |||
| _A_, | |||
| _lda_ ) |
| [in] | _dir_ | Unused parameter |
| [in] | _uplo_ | Unused parameter |
| [in] | _kl_ | Unused parameter |
| [in] | _ku_ | Unused parameter |
| [in] | _cfrom_ | Unused parameter |
| [in] | _cto_ | The scaling factor of the matrix A |
| [in] | _m_ | The number of rows of the matrix A |
| [in] | _n_ | The number of columns of the matrix A |
| [in,out] | _A_ | On entry the lda-by-n matrix to scale. On exit, the matrix is multiplied by cto. |
| [in] | _lda_ | The leading dimension of the matrix A. lda >= max(1, m) |
Definition at line 737 of file d_spm_matrixvector.c.
Referenced by spm_dspmm(), and spmScalMat().
| typedef struct __spm_dmatvec_s __spm_dmatvec_t |
Definition at line 35 of file d_spm_matrixvector.c.
| typedef double(* __conj_fct_t) (double) |
Definition at line 40 of file d_spm_matrixvector.c.
| typedef int(* __loop_fct_t) (const __spm_dmatvec_t *) |
Definition at line 45 of file d_spm_matrixvector.c.
static |
Identity function.
| [in] | val | TODO |
Definition at line 62 of file d_spm_matrixvector.c.
static |
| [in] | nrhs | The number of RHS. |
| [in] | spm | The pointer to the sparse matrix structure. |
| [in] | Cloc | The local matrix of size ldcl -by- nrhs |
| [in] | ldcl | The leading dimension of Cloc. ldcl >= max( 1, spm->nexp ) |
| [out] | Cglb | On exit, contains the centralized version of the Cloc matrix. |
| [out] | ldcg | On exit, contains the leading dimension of the Cglb matrix. ldcg >= max(1, spm->gNexp ) |
Definition at line 948 of file d_spm_matrixvector.c.
References spmatrix_s::baseval, spmatrix_s::dof, spmatrix_s::dofs, spmatrix_s::gNexp, spmatrix_s::loc2glob, and spmatrix_s::n.
Referenced by spm_dspmm(), and spm_dspmv().
static |
| [in] | Bloc | The local B vector. |
| [in,out] | ldbl | The leading dimension of the local B vector. |
| [out] | Bglb | The global B vector. |
| [out] | ldbg | The leading dimension of the global B vector. |
Definition at line 1012 of file d_spm_matrixvector.c.
References d_spmGatherRHS(), and spmatrix_s::gNexp.
