SpM Handbook 1.2.4
All Data Structures Files Functions Variables Typedefs Enumerations Enumerator Macros Modules Pages
d_spm_rhs.c File Reference
#include "common.h"
Go to the source code of this file.
Functions
void d_spmExtractLocalRHS (int nrhs, const spmatrix_t *spm, const double *bglob, spm_int_t ldbg, double *bloc, spm_int_t ldbl)
 Stores the local values of a global RHS in the local one.
void d_spmReduceRHS (int nrhs, const spmatrix_t *spm, double *bglob, spm_int_t ldbg, double *bloc, spm_int_t ldbl)
 Reduce all the global coefficients of a rhs and store the local ones.
void d_spmGatherRHS (int nrhs, const spmatrix_t *spm, const double *b, spm_int_t ldb, int root, double *bg, spm_int_t ldbg)
 Gather all the global C coefficients and store the good ones in local.
Detailed Description
SParse Matrix package right hand side precision dependant routines.
Version
1.2.4
Author
Mathieu Faverge
Tony Delarue
Alycia Lisito
Date
2024-06-25
Generated arithmetic file from /builds/2mk6rsew/0/fpruvost/spm/src/z_spm_rhs.c, normal z -> d, Fri Nov 29 11:34:29 2024
Definition in file d_spm_rhs.c.
