SpM Handbook 1.3.0
Searching...
No Matches
Spm_dev_rhs
RHS routines. More...
file  s_spm_rhs.c
file  d_spm_rhs.c
file  c_spm_rhs.c
file  z_spm_rhs.c
Functions
int z_spmGenRHS (spm_rhstype_t type, int nrhs, const spmatrix_t *spm, void *x, int ldx, void *b, int ldb)
 Generate nrhs right hand side vectors associated to a given matrix to test a problem with a solver.
int z_spmGenMat (spm_rhstype_t type, int nrhs, const spmatrix_t *spm, void *alphaptr, unsigned long long int seed, void *A, int lda)
int z_spmCheckAxb (spm_fixdbl_t eps, int nrhs, const spmatrix_t *spm, void *x0, int ldx0, void *b, int ldb, const void *x, int ldx)
 Check the backward error, and the forward error if x0 is provided.
void z_spmGatherRHS (int nrhs, const spmatrix_t *spm, const spm_complex64_t *x, spm_int_t ldx, int root, spm_complex64_t *gx, spm_int_t ldgx)
 Gather all the global C coefficients and store the good ones in local.
void z_spmReduceRHS (int nrhs, const spmatrix_t *spm, spm_complex64_t *bglob, spm_int_t ldbg, spm_complex64_t *bloc, spm_int_t ldbl)
 Reduce all the global coefficients of a rhs and store the local ones.
void z_spmExtractLocalRHS (int nrhs, const spmatrix_t *spm, const spm_complex64_t *bglob, spm_int_t ldbg, spm_complex64_t *bloc, spm_int_t ldbl)
 Stores the local values of a global RHS in the local one.
int z_spmRhsGenRndShm (const spmatrix_t *spm, spm_complex64_t scale, spm_int_t n, spm_complex64_t *A, spm_int_t lda, int shift, unsigned long long int seed)
 Generate a set of vectors of random values in shared memory.
int z_spmRhsGenRndDist (const spmatrix_t *spm, spm_complex64_t alpha, spm_int_t n, spm_complex64_t *A, spm_int_t lda, int shift, unsigned long long int seed)
 Generate a set of vectors of random values in distributed memory.
int c_spmGenRHS (spm_rhstype_t type, int nrhs, const spmatrix_t *spm, void *x, int ldx, void *b, int ldb)
int c_spmGenMat (spm_rhstype_t type, int nrhs, const spmatrix_t *spm, void *alphaptr, unsigned long long int seed, void *A, int lda)
int c_spmCheckAxb (spm_fixdbl_t eps, int nrhs, const spmatrix_t *spm, void *x0, int ldx0, void *b, int ldb, const void *x, int ldx)
void c_spmGatherRHS (int nrhs, const spmatrix_t *spm, const spm_complex32_t *x, spm_int_t ldx, int root, spm_complex32_t *gx, spm_int_t ldgx)
void c_spmReduceRHS (int nrhs, const spmatrix_t *spm, spm_complex32_t *bglob, spm_int_t ldbg, spm_complex32_t *bloc, spm_int_t ldbl)
void c_spmExtractLocalRHS (int nrhs, const spmatrix_t *spm, const spm_complex32_t *bglob, spm_int_t ldbg, spm_complex32_t *bloc, spm_int_t ldbl)
int c_spmRhsGenRndShm (const spmatrix_t *spm, spm_complex32_t scale, spm_int_t n, spm_complex32_t *A, spm_int_t lda, int shift, unsigned long long int seed)
int c_spmRhsGenRndDist (const spmatrix_t *spm, spm_complex32_t alpha, spm_int_t n, spm_complex32_t *A, spm_int_t lda, int shift, unsigned long long int seed)
int d_spmGenRHS (spm_rhstype_t type, int nrhs, const spmatrix_t *spm, void *x, int ldx, void *b, int ldb)
int d_spmGenMat (spm_rhstype_t type, int nrhs, const spmatrix_t *spm, void *alphaptr, unsigned long long int seed, void *A, int lda)
int d_spmCheckAxb (spm_fixdbl_t eps, int nrhs, const spmatrix_t *spm, void *x0, int ldx0, void *b, int ldb, const void *x, int ldx)
void d_spmGatherRHS (int nrhs, const spmatrix_t *spm, const double *x, spm_int_t ldx, int root, double *gx, spm_int_t ldgx)
void d_spmReduceRHS (int nrhs, const spmatrix_t *spm, double *bglob, spm_int_t ldbg, double *bloc, spm_int_t ldbl)
void d_spmExtractLocalRHS (int nrhs, const spmatrix_t *spm, const double *bglob, spm_int_t ldbg, double *bloc, spm_int_t ldbl)
int d_spmRhsGenRndShm (const spmatrix_t *spm, double scale, spm_int_t n, double *A, spm_int_t lda, int shift, unsigned long long int seed)
int d_spmRhsGenRndDist (const spmatrix_t *spm, double alpha, spm_int_t n, double *A, spm_int_t lda, int shift, unsigned long long int seed)
int s_spmGenRHS (spm_rhstype_t type, int nrhs, const spmatrix_t *spm, void *x, int ldx, void *b, int ldb)
int s_spmGenMat (spm_rhstype_t type, int nrhs, const spmatrix_t *spm, void *alphaptr, unsigned long long int seed, void *A, int lda)
int s_spmCheckAxb (spm_fixdbl_t eps, int nrhs, const spmatrix_t *spm, void *x0, int ldx0, void *b, int ldb, const void *x, int ldx)
void s_spmGatherRHS (int nrhs, const spmatrix_t *spm, const float *x, spm_int_t ldx, int root, float *gx, spm_int_t ldgx)
void s_spmReduceRHS (int nrhs, const spmatrix_t *spm, float *bglob, spm_int_t ldbg, float *bloc, spm_int_t ldbl)
void s_spmExtractLocalRHS (int nrhs, const spmatrix_t *spm, const float *bglob, spm_int_t ldbg, float *bloc, spm_int_t ldbl)
int s_spmRhsGenRndShm (const spmatrix_t *spm, float scale, spm_int_t n, float *A, spm_int_t lda, int shift, unsigned long long int seed)
int s_spmRhsGenRndDist (const spmatrix_t *spm, float alpha, spm_int_t n, float *A, spm_int_t lda, int shift, unsigned long long int seed)
static unsigned long long int Rnd64_jump (unsigned long long int n, unsigned long long int seed)
 Random generator from the HPL library.
static void s_updateRndVal (float scale, float *val, unsigned long long int *ran)
 Generate a value of the RHS.
static int s_spmRhsGenOne (const spmatrix_t *spm, float alpha, spm_int_t n, float *A, spm_int_t lda)
 Generate a set of vectors of constant values.
static int s_spmRhsGenI (const spmatrix_t *spm, float alpha, spm_int_t n, float *A, spm_int_t lda)
 Generate a set of vectors x[i] = alpha * ( i [+ i* I ] ).
static void d_updateRndVal (double scale, double *val, unsigned long long int *ran)
static int d_spmRhsGenOne (const spmatrix_t *spm, double alpha, spm_int_t n, double *A, spm_int_t lda)
static int d_spmRhsGenI (const spmatrix_t *spm, double alpha, spm_int_t n, double *A, spm_int_t lda)
static void c_updateRndVal (spm_complex32_t scale, spm_complex32_t *val, unsigned long long int *ran)
static int c_spmRhsGenOne (const spmatrix_t *spm, spm_complex32_t alpha, spm_int_t n, spm_complex32_t *A, spm_int_t lda)
static int c_spmRhsGenI (const spmatrix_t *spm, spm_complex32_t alpha, spm_int_t n, spm_complex32_t *A, spm_int_t lda)
static void z_updateRndVal (spm_complex64_t scale, spm_complex64_t *val, unsigned long long int *ran)
static int z_spmRhsGenOne (const spmatrix_t *spm, spm_complex64_t alpha, spm_int_t n, spm_complex64_t *A, spm_int_t lda)
static int z_spmRhsGenI (const spmatrix_t *spm, spm_complex64_t alpha, spm_int_t n, spm_complex64_t *A, spm_int_t lda)
Detailed Description
RHS routines.
Subroutines for random vector generation to be used in testings.
Function Documentation
◆ z_spmGenRHS()
int z_spmGenRHS ( spm_rhstype_t type,
int nrhs,
const spmatrix_t * spm,
void * x,
int ldx,
void * b,
int ldb )
Parameters
[in]typeDefines how to compute the vector b.
  • SpmRhsOne: b is computed such that x = 1 [ + I ]
  • SpmRhsI: b is computed such that x = i [ + i * I ]
  • SpmRhsRndX: b is computed by matrix-vector product, such that is a random vector in the range [-0.5, 0.5]
  • SpmRhsRndB: b is computed randomly and x is not computed.
[in]nrhsDefines the number of right hand side that must be generated.
[in]spmThe sparse matrix uses to generate the right hand side, and the solution of the full problem.
[out]xOn exit, if x != NULL, then the x vector(s) generated to compute b is returned. Must be of size at least ldx * spm->n.
[in]ldxDefines the leading dimension of x when multiple right hand sides are available. ldx >= spm->n.
[in,out]bb must be an allocated matrix of size at least ldb * nrhs. On exit, b is initialized as defined by the type parameter.
[in]ldbDefines the leading dimension of b when multiple right hand sides are available. ldb >= spm->n.
Return values
SPM_SUCCESSif the b vector has been computed succesfully,
SPM_ERR_BADPARAMETERotherwise.
Definition at line 73 of file z_spm_genrhs.c.
References spmatrix_s::gN, spmatrix_s::nexp, SPM_ERR_BADPARAMETER, SPM_SUCCESS, spm_zspmm(), SpmFrobeniusNorm, SpmLeft, SpmNoTrans, spmatrix_s::values, z_spmGenMat(), and z_spmNorm().
Referenced by spmGenRHS().
◆ z_spmGenMat()
int z_spmGenMat ( spm_rhstype_t type,
int nrhs,
void * alphaptr,
void * A,
int lda )
Parameters
[in]alphaptrThe pointer to the scaling factor of the matrix.
[in]seedRandom seed generator.
[out]AThe generated matrix. It has to be preallocated with a size lda -by- nrhs.
[in]ldaDefines the leading dimension of A when multiple right hand sides are available. lda >= spm->nexp.
Return values
Definition at line 783 of file z_spm_genmat.c.
References spmatrix_s::replicated, SPM_ERR_BADPARAMETER, SPM_SUCCESS, z_spmRhsGenI(), z_spmRhsGenOne(), z_spmRhsGenRndDist(), and z_spmRhsGenRndShm().
Referenced by spmGenMat(), and z_spmGenRHS().
◆ z_spmCheckAxb()
int z_spmCheckAxb ( spm_fixdbl_t eps,
int nrhs,
void * x0,
int ldx0,
void * b,
int ldb,
const void * x,
int ldx )
Parameters
[in]epsThe epsilon threshold used for the refinement step. -1. to use the machine precision.
[in,out]x0If x0 != NULL, the forward error is computed. On exit, x0 stores (x0-x)
[in]ldx0Defines the leading dimension of x0 when multiple right hand sides are available. ldx0 >= spm->n.
[in,out]bb is a matrix of size at least ldb * nrhs. On exit, b stores Ax-b.
[in]xContains the solution computed by the solver.
Return values
SPM_SUCCESSif the tests are succesfull
1,ifone of the test failed
Compute the starting norms
Compute r = b - A * x
Compute r = x0 - x
Definition at line 203 of file z_spm_genrhs.c.
References CBLAS_SADDR, spmatrix_s::nexp, spm_zspmm(), SpmFrobeniusNorm, SpmInfNorm, SpmLeft, spmNorm(), SpmNoTrans, SpmOneNorm, and z_spmNormMat().
Referenced by spmCheckAxb().
◆ z_spmGatherRHS()
void z_spmGatherRHS ( int nrhs,
const spm_complex64_t * b,
spm_int_t ldb,
int root,
spm_complex64_t * bg,
spm_int_t ldbg )
Parameters
[in]spmThe sparse matrix spm
[in]nrhsNumber of rhs vectors.
[in]bThe local RHS array of size ldb-by-nrhs.
[in]ldbThe leading dimension of the b array. ldb >= max(1, spm->nexp)
[in]rootClustnum where the complete vector will be gathered. -1 if you want to gather the data on all nodes.
[in,out]bgOn entry, the allocated ldbg-by-nrhs array to store the gathered RHS.
[in]ldbgThe leading dimension of the bg array. ldbg >= max(1, spm->gNexp)
Definition at line 165 of file z_spm_rhs.c.
References spmatrix_s::baseval, spmatrix_s::clustnbr, spmatrix_s::clustnum, spmatrix_s::comm, spmatrix_s::dof, spmatrix_s::dofs, spmatrix_s::gNexp, spmatrix_s::loc2glob, spmatrix_s::n, spmatrix_s::nexp, spmatrix_s::replicated, and SPM_MPI_INT.
Referenced by spmGatherRHS(), and z_spmm_build_Btmp().
◆ z_spmReduceRHS()
void z_spmReduceRHS ( int nrhs,
spm_complex64_t * bglob,
spm_int_t ldbg,
spm_complex64_t * bloc,
spm_int_t ldbl )
Parameters
[in,out]bglobThe global rhs to reduce.
[in]ldbgLeading dimension of the global bglob matrix.
[in,out]blocLocal rhs matrix.
[in]ldblLeading dimension of the local bloc matrix.
Definition at line 109 of file z_spm_rhs.c.
References spmatrix_s::clustnbr, spmatrix_s::comm, spmatrix_s::gNexp, spmatrix_s::replicated, and z_spmExtractLocalRHS().
Referenced by spm_zspmm(), spm_zspmv(), and spmReduceRHS().
◆ z_spmExtractLocalRHS()
void z_spmExtractLocalRHS ( int nrhs,
const spm_complex64_t * bglob,
spm_int_t ldbg,
spm_int_t ldbl )
Parameters
[in,out]bglobThe global RHS.
[in]ldblLeading dimension of the local bloc vector.
Definition at line 51 of file z_spm_rhs.c.
References spmatrix_s::baseval, spmatrix_s::dof, spmatrix_s::dofs, spmatrix_s::loc2glob, spmatrix_s::n, and spmatrix_s::replicated.
Referenced by spmExtractLocalRHS(), and z_spmReduceRHS().
◆ z_spmRhsGenRndShm()
int z_spmRhsGenRndShm ( const spmatrix_t * spm,
spm_int_t n,
spm_complex64_t * A,
spm_int_t lda,
int shift,
unsigned long long int seed )
Parameters
[in]spmThe sparse matrix associated to the right hand side.
[in]scaleScaling factor for each value of the vector.
[in]nThe number of columns in A. n >= 0.
[in,out]AOn entry, the lda-by-n matrix to be initialized. On exit, the matrix initialized.
[in]ldaThe leading dimension of the matrix A. lda >= max(1,spm->nexp).
[in]shiftThe initial shift in the random sequence.
[in]seedThe seed used for random generation. Must be the same for all tiles initialized with this routine.
Return values
SPM_SUCCESSto match prototype of equivalent function
Definition at line 149 of file z_spm_genmat.c.
References spmatrix_s::gNexp, spmatrix_s::nexp, Rnd64_jump(), SPM_SUCCESS, and z_updateRndVal().
Referenced by z_spmGenMat().
◆ z_spmRhsGenRndDist()
int z_spmRhsGenRndDist ( const spmatrix_t * spm,
spm_int_t n,
spm_int_t lda,
int shift,
Parameters
[in]alphaScaling factor for each value of the vector.
Return values
SPM_SUCCESSon success
SPM_ERR_BADPARAMETERif the provided spm is incorrect
Definition at line 422 of file z_spm_genmat.c.
References spmatrix_s::fmttype, SpmIJV, z_spm_rhs_dist_genRnd_csx(), and z_spm_rhs_dist_genRnd_ijv().
◆ c_spmGenRHS()
int c_spmGenRHS ( spm_rhstype_t type,
int nrhs,
void * x,
int ldx,
void * b,
int ldb )
Parameters
Return values
Definition at line 73 of file c_spm_genrhs.c.
References c_spmGenMat(), c_spmNorm(), spmatrix_s::gN, spmatrix_s::nexp, spm_cspmm(), SPM_ERR_BADPARAMETER, SPM_SUCCESS, SpmFrobeniusNorm, SpmLeft, SpmNoTrans, and spmatrix_s::values.
◆ c_spmGenMat()
int c_spmGenMat ( spm_rhstype_t type,
int nrhs,
void * alphaptr,
void * A,
int lda )
Parameters
Return values
Definition at line 783 of file c_spm_genmat.c.
References c_spmRhsGenI(), c_spmRhsGenOne(), c_spmRhsGenRndDist(), c_spmRhsGenRndShm(), spmatrix_s::replicated, SPM_ERR_BADPARAMETER, and SPM_SUCCESS.
Referenced by c_spmGenRHS(), and spmGenMat().
◆ c_spmCheckAxb()
int c_spmCheckAxb ( spm_fixdbl_t eps,
int nrhs,
void * x0,
int ldx0,
void * b,
int ldb,
const void * x,
int ldx )
Parameters
Return values
Compute r = x0 - x
Definition at line 203 of file c_spm_genrhs.c.
References c_spmNormMat(), CBLAS_SADDR, spmatrix_s::nexp, spm_cspmm(), SpmFrobeniusNorm, SpmInfNorm, SpmLeft, spmNorm(), SpmNoTrans, and SpmOneNorm.
◆ c_spmGatherRHS()
void c_spmGatherRHS ( int nrhs,
const spm_complex32_t * b,
spm_int_t ldb,
int root,
spm_complex32_t * bg,
spm_int_t ldbg )
Parameters
Definition at line 165 of file c_spm_rhs.c.
Referenced by c_spmm_build_Btmp(), and spmGatherRHS().
◆ c_spmReduceRHS()
void c_spmReduceRHS ( int nrhs,
spm_complex32_t * bglob,
spm_int_t ldbg,
spm_complex32_t * bloc,
spm_int_t ldbl )
Parameters
Definition at line 109 of file c_spm_rhs.c.
References c_spmExtractLocalRHS(), spmatrix_s::clustnbr, spmatrix_s::comm, spmatrix_s::gNexp, and spmatrix_s::replicated.
Referenced by spm_cspmm(), spm_cspmv(), and spmReduceRHS().
◆ c_spmExtractLocalRHS()
void c_spmExtractLocalRHS ( int nrhs,
const spm_complex32_t * bglob,
spm_int_t ldbg,
spm_int_t ldbl )
Parameters
Definition at line 51 of file c_spm_rhs.c.
Referenced by c_spmReduceRHS(), and spmExtractLocalRHS().
◆ c_spmRhsGenRndShm()
int c_spmRhsGenRndShm ( const spmatrix_t * spm,
spm_int_t n,
spm_complex32_t * A,
spm_int_t lda,
int shift,
Parameters
Return values
Definition at line 149 of file c_spm_genmat.c.
References c_updateRndVal(), spmatrix_s::gNexp, spmatrix_s::nexp, Rnd64_jump(), and SPM_SUCCESS.
Referenced by c_spmGenMat().
◆ c_spmRhsGenRndDist()
int c_spmRhsGenRndDist ( const spmatrix_t * spm,
spm_int_t n,
spm_int_t lda,
int shift,
Parameters
Return values
Definition at line 422 of file c_spm_genmat.c.
References c_spm_rhs_dist_genRnd_csx(), c_spm_rhs_dist_genRnd_ijv(), spmatrix_s::fmttype, and SpmIJV.
◆ d_spmGenRHS()
int d_spmGenRHS ( spm_rhstype_t type,
int nrhs,
void * x,
int ldx,
void * b,
int ldb )
Parameters
Return values
Definition at line 73 of file d_spm_genrhs.c.
References d_spmGenMat(), d_spmNorm(), spmatrix_s::gN, spmatrix_s::nexp, spm_dspmm(), SPM_ERR_BADPARAMETER, SPM_SUCCESS, SpmFrobeniusNorm, SpmLeft, SpmNoTrans, and spmatrix_s::values.
◆ d_spmGenMat()
int d_spmGenMat ( spm_rhstype_t type,
int nrhs,
void * alphaptr,
void * A,
int lda )
Parameters
Return values
Definition at line 783 of file d_spm_genmat.c.
References d_spmRhsGenI(), d_spmRhsGenOne(), d_spmRhsGenRndDist(), d_spmRhsGenRndShm(), spmatrix_s::replicated, SPM_ERR_BADPARAMETER, and SPM_SUCCESS.
Referenced by d_spmGenRHS(), and spmGenMat().
◆ d_spmCheckAxb()
int d_spmCheckAxb ( spm_fixdbl_t eps,
int nrhs,
void * x0,
int ldx0,
void * b,
int ldb,
const void * x,
int ldx )
Parameters
Return values
Compute r = x0 - x
Definition at line 203 of file d_spm_genrhs.c.
References d_spmNormMat(), spmatrix_s::nexp, spm_dspmm(), SpmFrobeniusNorm, SpmInfNorm, SpmLeft, spmNorm(), SpmNoTrans, and SpmOneNorm.
◆ d_spmGatherRHS()
void d_spmGatherRHS ( int nrhs,
const double * b,
spm_int_t ldb,
int root,
double * bg,
spm_int_t ldbg )
Parameters
Definition at line 165 of file d_spm_rhs.c.
Referenced by d_spmm_build_Btmp(), and spmGatherRHS().
◆ d_spmReduceRHS()
void d_spmReduceRHS ( int nrhs,
double * bglob,
spm_int_t ldbg,
double * bloc,
spm_int_t ldbl )
Parameters
Definition at line 109 of file d_spm_rhs.c.
References spmatrix_s::clustnbr, spmatrix_s::comm, d_spmExtractLocalRHS(), spmatrix_s::gNexp, and spmatrix_s::replicated.
Referenced by spm_dspmm(), spm_dspmv(), and spmReduceRHS().
◆ d_spmExtractLocalRHS()
void d_spmExtractLocalRHS ( int nrhs,
const double * bglob,
spm_int_t ldbg,
double * bloc,
spm_int_t ldbl )
Parameters
Definition at line 51 of file d_spm_rhs.c.
Referenced by d_spmReduceRHS(), and spmExtractLocalRHS().
◆ d_spmRhsGenRndShm()
int d_spmRhsGenRndShm ( const spmatrix_t * spm,
double scale,
spm_int_t n,
double * A,
spm_int_t lda,
int shift,
Parameters
Return values
Definition at line 149 of file d_spm_genmat.c.
References d_updateRndVal(), spmatrix_s::gNexp, spmatrix_s::nexp, Rnd64_jump(), and SPM_SUCCESS.
Referenced by d_spmGenMat().
◆ d_spmRhsGenRndDist()
int d_spmRhsGenRndDist ( const spmatrix_t * spm,
double alpha,
spm_int_t n,
double * A,
spm_int_t lda,
int shift,
Parameters
Return values
Definition at line 422 of file d_spm_genmat.c.
References d_spm_rhs_dist_genRnd_csx(), d_spm_rhs_dist_genRnd_ijv(), spmatrix_s::fmttype, and SpmIJV.
◆ s_spmGenRHS()
int s_spmGenRHS ( spm_rhstype_t type,
int nrhs,
void * x,
int ldx,
void * b,
int ldb )
Parameters
Return values
Definition at line 73 of file s_spm_genrhs.c.
References spmatrix_s::gN, spmatrix_s::nexp, s_spmGenMat(), s_spmNorm(), SPM_ERR_BADPARAMETER, spm_sspmm(), SPM_SUCCESS, SpmFrobeniusNorm, SpmLeft, SpmNoTrans, and spmatrix_s::values.
◆ s_spmGenMat()
int s_spmGenMat ( spm_rhstype_t type,
int nrhs,
void * alphaptr,
void * A,
int lda )
Parameters
Return values
Definition at line 783 of file s_spm_genmat.c.
References spmatrix_s::replicated, s_spmRhsGenI(), s_spmRhsGenOne(), s_spmRhsGenRndDist(), s_spmRhsGenRndShm(), SPM_ERR_BADPARAMETER, and SPM_SUCCESS.
Referenced by s_spmGenRHS(), and spmGenMat().
◆ s_spmCheckAxb()
int s_spmCheckAxb ( spm_fixdbl_t eps,
int nrhs,
void * x0,
int ldx0,
void * b,
int ldb,
const void * x,
int ldx )
Parameters
Return values
Compute r = x0 - x
Definition at line 203 of file s_spm_genrhs.c.
References spmatrix_s::nexp, s_spmNormMat(), spm_sspmm(), SpmFrobeniusNorm, SpmInfNorm, SpmLeft, spmNorm(), SpmNoTrans, and SpmOneNorm.
◆ s_spmGatherRHS()
void s_spmGatherRHS ( int nrhs,
const float * b,
spm_int_t ldb,
int root,
float * bg,
spm_int_t ldbg )
Parameters
Definition at line 165 of file s_spm_rhs.c.
Referenced by s_spmm_build_Btmp(), and spmGatherRHS().
◆ s_spmReduceRHS()
void s_spmReduceRHS ( int nrhs,
float * bglob,
spm_int_t ldbg,
float * bloc,
spm_int_t ldbl )
Parameters
Definition at line 109 of file s_spm_rhs.c.
References spmatrix_s::clustnbr, spmatrix_s::comm, spmatrix_s::gNexp, spmatrix_s::replicated, and s_spmExtractLocalRHS().
Referenced by spm_sspmm(), spm_sspmv(), and spmReduceRHS().
◆ s_spmExtractLocalRHS()
void s_spmExtractLocalRHS ( int nrhs,
const float * bglob,
spm_int_t ldbg,
float * bloc,
spm_int_t ldbl )
Parameters
Definition at line 51 of file s_spm_rhs.c.
Referenced by s_spmReduceRHS(), and spmExtractLocalRHS().
◆ s_spmRhsGenRndShm()
int s_spmRhsGenRndShm ( const spmatrix_t * spm,
float scale,
spm_int_t n,
float * A,
spm_int_t lda,
int shift,
Parameters
Return values
Definition at line 149 of file s_spm_genmat.c.
References spmatrix_s::gNexp, spmatrix_s::nexp, Rnd64_jump(), s_updateRndVal(), and SPM_SUCCESS.
Referenced by s_spmGenMat().
◆ s_spmRhsGenRndDist()
int s_spmRhsGenRndDist ( const spmatrix_t * spm,
float alpha,
spm_int_t n,
float * A,
spm_int_t lda,
int shift,
Parameters
Return values
Definition at line 422 of file s_spm_genmat.c.
References spmatrix_s::fmttype, s_spm_rhs_dist_genRnd_csx(), s_spm_rhs_dist_genRnd_ijv(), and SpmIJV.
◆ Rnd64_jump()
unsigned long long int Rnd64_jump ( unsigned long long int n,
static
Parameters
[in]nNumber of elements to jump over in the generator cycle.
[in]seed
Return values
arandom integer value
Definition at line 49 of file s_spm_genmat.c.
Referenced by s_spm_rhs_dist_genRnd_csx(), s_spm_rhs_dist_genRnd_ijv(), and s_spmRhsGenRndShm().
◆ s_updateRndVal()
void s_updateRndVal ( float scale,
float * val,
unsigned long long int * ran )
static
Parameters
[in]scaleScaling factor for each randomized value.
[in,out]valThe value that will be updated
[in,out]ranThe current random value.
Definition at line 98 of file s_spm_genmat.c.
◆ s_spmRhsGenOne()
int s_spmRhsGenOne ( const spmatrix_t * spm,
float alpha,
spm_int_t n,
float * A,
spm_int_t lda )
static
Parameters
[in]alphaInitialize each value to alpha [ + I * alpha ]
Return values
Definition at line 469 of file s_spm_genmat.c.
References spmatrix_s::nexp, and SPM_SUCCESS.
◆ s_spmRhsGenI()
int s_spmRhsGenI ( const spmatrix_t * spm,
float alpha,
spm_int_t n,
float * A,
spm_int_t lda )
static
Parameters
Return values
Definition at line 723 of file s_spm_genmat.c.
References spmatrix_s::fmttype, s_spm_rhs_genI_csx(), s_spm_rhs_genI_ijv(), and SpmIJV.
◆ d_updateRndVal()
void d_updateRndVal ( double scale,
double * val,
static
Parameters
Definition at line 98 of file d_spm_genmat.c.
Referenced by d_spm_rhs_dist_genRnd_csx(), d_spm_rhs_dist_genRnd_ijv(), and d_spmRhsGenRndShm().
◆ d_spmRhsGenOne()
int d_spmRhsGenOne ( const spmatrix_t * spm,
double alpha,
spm_int_t n,
double * A,
spm_int_t lda )
static
Parameters
Return values
Definition at line 469 of file d_spm_genmat.c.
◆ d_spmRhsGenI()
int d_spmRhsGenI ( const spmatrix_t * spm,
double alpha,
spm_int_t n,
double * A,
spm_int_t lda )
static
Parameters
Return values
Definition at line 723 of file d_spm_genmat.c.
References d_spm_rhs_genI_csx(), d_spm_rhs_genI_ijv(), spmatrix_s::fmttype, and SpmIJV.
◆ c_updateRndVal()
void c_updateRndVal ( spm_complex32_t scale,
spm_complex32_t * val,
static
Parameters
Definition at line 98 of file c_spm_genmat.c.
Referenced by c_spm_rhs_dist_genRnd_csx(), c_spm_rhs_dist_genRnd_ijv(), and c_spmRhsGenRndShm().
◆ c_spmRhsGenOne()
int c_spmRhsGenOne ( const spmatrix_t * spm,
spm_int_t n,
spm_int_t lda )
static
Parameters
Return values
Definition at line 469 of file c_spm_genmat.c.
◆ c_spmRhsGenI()
int c_spmRhsGenI ( const spmatrix_t * spm,
spm_int_t n,
spm_int_t lda )
static
Parameters
Return values
Definition at line 723 of file c_spm_genmat.c.
References c_spm_rhs_genI_csx(), c_spm_rhs_genI_ijv(), spmatrix_s::fmttype, and SpmIJV.
◆ z_updateRndVal()
void z_updateRndVal ( spm_complex64_t scale,
spm_complex64_t * val,
static
Parameters
Definition at line 98 of file z_spm_genmat.c.
Referenced by z_spm_rhs_dist_genRnd_csx(), z_spm_rhs_dist_genRnd_ijv(), and z_spmRhsGenRndShm().
◆ z_spmRhsGenOne()
int z_spmRhsGenOne ( const spmatrix_t * spm,
spm_int_t n,
spm_int_t lda )
static
Parameters
Return values
Definition at line 469 of file z_spm_genmat.c.
◆ z_spmRhsGenI()
int z_spmRhsGenI ( const spmatrix_t * spm,
spm_int_t n,
spm_int_t lda )
static
Parameters
Return values
Definition at line 723 of file z_spm_genmat.c.
References spmatrix_s::fmttype, SpmIJV, z_spm_rhs_genI_csx(), and z_spm_rhs_genI_ijv().
