30struct __spm_cmatvec_s;
66#if defined(PRECISION_c) || defined(PRECISION_z)
92struct __spm_cmatvec_s {
175 for(jj=0; jj<dofj; jj++)
177 for(ii=0; ii<dofi; ii++, values++)
179 y[ row + (ii * incy) ] += alpha * conjA_fct( *values ) * x[ col +(jj * incx) ];
245 for(jj=0; jj<dofj; jj++)
247 for(ii=0; ii<dofi; ii++, values++)
249 y[ row + (ii * incy) ] += alpha * conjA_fct( *values ) * x[ col +(jj * incx) ];
250 y[ col + (jj * incy) ] += alpha * conjAt_fct( *values ) * x[ row +(ii * incx) ];
302__spm_cmatvec_dof_loop_sy_csr(
spm_int_t row,
315 __spm_cmatvec_dof_loop_sy( row, dofi, col, dofj, y, incy, x, incx, values, conjAt_fct, conjA_fct, alpha );
344 const spm_int_t *loc2glob = args->loc2glob;
361 = ( args->follow_x ) ? __spm_cmatvec_dof_loop_sy_csr : __spm_cmatvec_dof_loop_sy;
363 for( j=0; j<n; j++, colptr++ )
365 jg = (loc2glob == NULL) ? j : loc2glob[j] - baseval ;
366 dofj = ( dof > 0 ) ? dof : dofs[jg+1] - dofs[jg];
367 col = ( dof > 0 ) ? dof * jg : dofs[jg] - baseval;
368 for( i=colptr[0]; i<colptr[1]; i++, rowptr++ )
370 ig = *rowptr - baseval;
371 dofi = ( dof > 0 ) ? dof : dofs[ig+1] - dofs[ig];
372 row = ( dof > 0 ) ? dof * ig : dofs[ig] - baseval;
374 dof_loop_sy( row, dofi, col, dofj, y, incy, x, incx, values, conjA_fct, conjAt_fct, alpha );
377 __spm_cmatvec_dof_loop( row, dofi, col, dofj, y, incy, x, incx, values, conjA_fct, alpha );
411 const spm_int_t *loc2glob = args->loc2glob;
422 if ( args->follow_x ) {
423 for( j = 0; j < n; j++, colptr++ )
425 jg = (loc2glob == NULL) ? j : loc2glob[j] - baseval;
426 dofj = ( dof > 0 ) ? dof : dofs[jg+1] - dofs[jg];
427 for( i=colptr[0]; i<colptr[1]; i++, rowptr++ )
429 ig = *rowptr - baseval;
430 dofi = ( dof > 0 ) ? dof : dofs[ig+1] - dofs[ig];
431 row = ( dof > 0 ) ? dof * ig : dofs[ig] - baseval;
432 __spm_cmatvec_dof_loop( row, dofi, 0, dofj, y, incy, x, 1, values, conjA_fct, alpha );
433 values += dofi * dofj;
439 for( j=0; j<n; j++, colptr++ )
441 jg = (loc2glob == NULL) ? j : loc2glob[j] - baseval;
442 dofj = ( dof > 0 ) ? dof : dofs[jg+1] - dofs[jg];
443 for( i=colptr[0]; i<colptr[1]; i++, rowptr++ )
445 ig = *rowptr - baseval;
446 dofi = ( dof > 0 ) ? dof : dofs[ig+1] - dofs[ig];
447 row = ( dof > 0 ) ? dof * ig : dofs[ig] - baseval;
448 __spm_cmatvec_dof_loop( 0, dofj, row, dofi, y, 1, x, incx, values, conjA_fct, alpha );
449 values += dofi * dofj;
494 for( i=0; i<nnz; i++, colptr++, rowptr++ )
496 ig = *rowptr - baseval;
497 jg = *colptr - baseval;
499 dofj = ( dof > 0 ) ? dof : dofs[jg+1] - dofs[jg];
500 dofi = ( dof > 0 ) ? dof : dofs[ig+1] - dofs[ig];
502 row = ( dof > 0 ) ? dof * ig : dofs[ig] - baseval;
503 col = ( dof > 0 ) ? dof * jg : dofs[jg] - baseval;
506 __spm_cmatvec_dof_loop_sy( row, dofi, col, dofj, y, incy, x, incx, values, conjA_fct, conjAt_fct, alpha );
509 __spm_cmatvec_dof_loop( row, dofi, col, dofj, y, incy, x, incx, values, conjA_fct, alpha );
541__spm_cmatvec_dofs_local(
const spm_int_t *dofs,
548 result = calloc( gN ,
sizeof(
spm_int_t) );
550 for ( i = 0; i < gN; i++, glob2loc++, resptr++, dofs++ )
552 if( *glob2loc >= 0 ) {
554 acc += dofs[1] - dofs[0];
586 const spm_int_t *glob2loc = args->glob2loc;
599 assert( ((dof > 0) && (dofs == NULL)) ||
600 ((dof <= 0) && (dofs != NULL)) );
602 if( (dofs != NULL) && (glob2loc != NULL) ) {
603 dof_local = __spm_cmatvec_dofs_local( dofs, glob2loc, args->gN );
604 assert( dof_local != NULL );
607 if( args->follow_x ) {
608 for( i=0; i<nnz; i++, colptr++, rowptr++ )
610 ig = *rowptr - baseval;
611 jg = *colptr - baseval;
613 dofj = ( dof > 0 ) ? dof : dofs[jg+1] - dofs[jg];
614 dofi = ( dof > 0 ) ? dof : dofs[ig+1] - dofs[ig];
616 row = ( dof > 0 ) ? dof * ig : dofs[ig] - baseval;
617 if ( glob2loc == NULL ) {
618 col = ( dof > 0 ) ? dof * jg : dofs[jg] - baseval;
621 assert( glob2loc[jg] >= 0 );
622 col = ( dof > 0 ) ? dof * glob2loc[jg] : dof_local[jg];
624 __spm_cmatvec_dof_loop( row, dofi, col, dofj, y, incy, x, incx, values, conjA_fct, alpha );
629 for( i=0; i<nnz; i++, colptr++, rowptr++ )
631 ig = *rowptr - baseval;
632 jg = *colptr - baseval;
634 dofj = ( dof > 0 ) ? dof : dofs[jg+1] - dofs[jg];
635 dofi = ( dof > 0 ) ? dof : dofs[ig+1] - dofs[ig];
637 col = ( dof > 0 ) ? dof * jg : dofs[jg] - baseval;
638 if ( glob2loc == NULL ) {
639 row = ( dof > 0 ) ? dof * ig : dofs[ig] - baseval;
642 assert( glob2loc[ig] >= 0 );
643 row = ( dof > 0 ) ? dof * glob2loc[ig] : dof_local[ig];
645 __spm_cmatvec_dof_loop( row, dofi, col, dofj, y, incy, x, incx, values, conjA_fct, alpha );
650 if(dof_local != NULL) {
657#if !defined(LAPACKE_WITH_LASCL)
691 for( j=0; j<n; j++ ) {
692 for( i=0; i<m; i++, A++ ) {
737#define LAPACKE_clascl_work( _dir_, _uplo_, _kl_, _ku_, _cfrom_, _cto_, _m_, _n_, _A_, _lda_ ) \
738 __spm_clascl( (_cto_), (_m_), (_n_), (_A_), (_lda_) )
815 args->glob2loc = NULL;
817 args->dofs = A->
dofs;
825#if defined(PRECISION_c) || defined(PRECISION_z)
828 args->conjA_fct = __fct_conj;
829 args->conjAt_fct = __fct_conj;
834 args->conjA_fct = __fct_conj;
839 args->conjAt_fct = __fct_conj;
844 args->loop_fct = NULL;
860 args->loop_fct = (A->
mtxtype ==
SpmGeneral) ? __spm_cmatvec_ge_csx : __spm_cmatvec_sy_csx;
882 args->loop_fct = (A->
mtxtype ==
891 args->conjA_fct = args->conjAt_fct;
892 args->conjAt_fct = tmp_fct;
910 args->loop_fct = (A->
mtxtype ==
SpmGeneral) ? __spm_cmatvec_ge_ijv : __spm_cmatvec_sy_ijv;
964 for ( j=0; j<nrhs; j++ )
966 Cptr = Cloc + j * ldcl;
968 for ( i=0; i<spm->
n; i++, loc2glob++ )
970 ig = *loc2glob - baseval;
971 dof = (spm->
dof > 0) ? spm->
dof : spm->
dofs[ig+1] - spm->
dofs[ig];
972 idx = (spm->
dof > 0) ? spm->
dof * ig : spm->
dofs[ig] - baseval;
973 memcpy( (C + j * ldc + idx),
1130 fprintf(stderr,
"transB != SpmNoTrans not supported yet in spmv computations\n");
1145 rc = LAPACKE_claset_work( LAPACK_COL_MAJOR,
'A', M, N, 0., 0., C, ldc );
1154 if ( alpha == 0. ) {
1182 __spm_cmatvec_args_init( &args, side, transA, distribution,
1183 alpha, A, Btmp, ldbtmp, Ctmp, ldctmp );
1186 args.x = Btmp + r * ldbtmp;
1187 args.y = Ctmp + r * ldctmp;
1188 rc = args.loop_fct( &args );
1267 if ( alpha == 0. ) {
1271 assert( (incx == 1) && (incy == 1) );
1274 ldx = A->
nexp * incx;
1275 ldy = A->
nexp * incy;
1298 __spm_cmatvec_args_init( &args,
SpmLeft, trans, distribution,
1299 alpha, A, xtmp, ldxtmp, ytmp, ldytmp );
1300 rc = args.loop_fct( &args );
#define LAPACKE_clascl_work(_dir_, _uplo_, _kl_, _ku_, _cfrom_, _cto_, _m_, _n_, _A_, _lda_)
Alias if Lapacke zlscl is not available.
spm_complex32_t(* __conj_fct_t)(spm_complex32_t)
Typedef to define the op function applied to the element (id or conjf).
struct __spm_cmatvec_s __spm_cmatvec_t
Typedef associated to structure.
static void c_spmm_build_Ctmp(int nrhs, const spmatrix_t *spm, const spm_complex32_t *Cloc, spm_int_t ldcl, spm_complex32_t **Cglb, spm_int_t *ldcg)
Build a global C RHS, set to 0 for remote datas.
static void c_spmm_build_Btmp(int nrhs, const spmatrix_t *spm, const spm_complex32_t *Bloc, spm_int_t ldbl, spm_complex32_t **Bglb, spm_int_t *ldbg)
Build a global B vector by gathering datas from all nodes.
static spm_complex32_t __fct_id(spm_complex32_t val)
Identity function.
int(* __loop_fct_t)(const __spm_cmatvec_t *)
Typedef to the main loop function performing the matvec operation.
#define CBLAS_SADDR(_a_)
Macro to get the address if need in the cblas calls.
#define SpmDistByColumn
Distribution of the matrix storage.
enum spm_trans_e spm_trans_t
Transpostion.
enum spm_side_e spm_side_t
Side of the operation.
int spm_cspmv(spm_trans_t trans, spm_complex32_t alpha, const spmatrix_t *A, const spm_complex32_t *x, spm_int_t incx, spm_complex32_t beta, spm_complex32_t *y, spm_int_t incy)
compute the matrix-vector product:
int spm_cspmm(spm_side_t side, spm_trans_t transA, spm_trans_t transB, spm_int_t K, spm_complex32_t alpha, const spmatrix_t *A, const spm_complex32_t *B, spm_int_t ldb, spm_complex32_t beta, spm_complex32_t *C, spm_int_t ldc)
Compute a matrix-matrix product.
void c_spmReduceRHS(int nrhs, const spmatrix_t *spm, spm_complex32_t *bglob, spm_int_t ldbg, spm_complex32_t *bloc, spm_int_t ldbl)
Reduce all the global coefficients of a rhs and store the local ones.
void c_spmGatherRHS(int nrhs, const spmatrix_t *spm, const spm_complex32_t *x, spm_int_t ldx, int root, spm_complex32_t *gx, spm_int_t ldgx)
Gather all the global C coefficients and store the good ones in local.
struct spmatrix_s spmatrix_t
The sparse matrix data structure.
int spm_int_t
The main integer datatype used in spm arrays.
float _Complex spm_complex32_t
The real complex arithmetic datatype.
float(* __conj_fct_t)(float)
Typedef to define the op function applied to the element (id or ).
static float __fct_id(float val)
Identity function.
int(* __loop_fct_t)(const __spm_smatvec_t *)
int spm_get_distribution(const spmatrix_t *spm)
Search the distribution pattern used in the spm structure.
