SpM Handbook 1.3.0
Searching...
No Matches
c_spm_matrixvector.c File Reference
#include "common.h"
#include <lapacke.h>
#include <cblas.h>
Go to the source code of this file.
Functions
int spm_cspmm (spm_side_t side, spm_trans_t transA, spm_trans_t transB, spm_int_t K, spm_complex32_t alpha, const spmatrix_t *A, const spm_complex32_t *B, spm_int_t ldb, spm_complex32_t beta, spm_complex32_t *C, spm_int_t ldc)
 Compute a matrix-matrix product.
int spm_cspmv (spm_trans_t trans, spm_complex32_t alpha, const spmatrix_t *A, const spm_complex32_t *x, spm_int_t incx, spm_complex32_t beta, spm_complex32_t *y, spm_int_t incy)
 compute the matrix-vector product:
#define LAPACKE_clascl_work(_dir_, _uplo_, _kl_, _ku_, _cfrom_, _cto_, _m_, _n_, _A_, _lda_)
 Alias if Lapacke zlscl is not available.
typedef struct __spm_cmatvec_s __spm_cmatvec_t
 Typedef associated to structure.
typedef spm_complex32_t(* __conj_fct_t) (spm_complex32_t)
 Typedef to define the op function applied to the element (id or conjf).
typedef int(* __loop_fct_t) (const __spm_cmatvec_t *)
 Typedef to the main loop function performing the matvec operation.
static spm_complex32_t __fct_id (spm_complex32_t val)
 Identity function.
static void c_spmm_build_Ctmp (int nrhs, const spmatrix_t *spm, const spm_complex32_t *Cloc, spm_int_t ldcl, spm_complex32_t **Cglb, spm_int_t *ldcg)
 Build a global C RHS, set to 0 for remote datas.
static void c_spmm_build_Btmp (int nrhs, const spmatrix_t *spm, const spm_complex32_t *Bloc, spm_int_t ldbl, spm_complex32_t **Bglb, spm_int_t *ldbg)
 Build a global B vector by gathering datas from all nodes.
Detailed Description
SParse Matrix package matrix-vector multiplication routines.
Version
1.3.0
Author
Matthieu Kuhn
Mathieu Faverge
Tony Delarue
Alycia Lisito
Date
2024-07-26
Generated arithmetic file from /builds/fpruvost/spm/src/z_spm_matrixvector.c, normal z -> c, Fri Oct 23 13:04:58 2026
Definition in file c_spm_matrixvector.c.
Macro Definition Documentation
◆ LAPACKE_clascl_work
#define LAPACKE_clascl_work ( _dir_,
_uplo_,
_kl_,
_ku_,
_cfrom_,
_cto_,
_m_,
_n_,
_A_,
_lda_ )
Value:
__spm_clascl( (_cto_), (_m_), (_n_), (_A_), (_lda_) )
Parameters
[in]_dir_Unused parameter
[in]_uplo_Unused parameter
[in]_kl_Unused parameter
[in]_ku_Unused parameter
[in]_cfrom_Unused parameter
[in]_cto_The scaling factor of the matrix A
[in]_m_The number of rows of the matrix A
[in]_n_The number of columns of the matrix A
[in,out]_A_On entry the lda-by-n matrix to scale. On exit, the matrix is multiplied by cto.
[in]_lda_The leading dimension of the matrix A. lda >= max(1, m)
Definition at line 737 of file c_spm_matrixvector.c.
Referenced by spm_cspmm(), and spmScalMat().
Typedef Documentation
◆ __spm_cmatvec_t
Definition at line 35 of file c_spm_matrixvector.c.
◆ __conj_fct_t
Definition at line 40 of file c_spm_matrixvector.c.
◆ __loop_fct_t
Definition at line 45 of file c_spm_matrixvector.c.
Function Documentation
◆ __fct_id()
spm_complex32_t __fct_id ( spm_complex32_t val)
static
Identity function.
Parameters
[in]valTODO
Returns
id(val)
Definition at line 62 of file c_spm_matrixvector.c.
◆ c_spmm_build_Ctmp()
void c_spmm_build_Ctmp ( int nrhs,
const spmatrix_t * spm,
const spm_complex32_t * Cloc,
spm_int_t ldcl,
spm_complex32_t ** Cglb,
spm_int_t * ldcg )
static
Parameters
[in]nrhsThe number of RHS.
[in]spmThe pointer to the sparse matrix structure.
[in]ClocThe local matrix of size ldcl -by- nrhs
[in]ldclThe leading dimension of Cloc. ldcl >= max( 1, spm->nexp )
[out]CglbOn exit, contains the centralized version of the Cloc matrix.
[out]ldcgOn exit, contains the leading dimension of the Cglb matrix. ldcg >= max(1, spm->gNexp )
Definition at line 948 of file c_spm_matrixvector.c.
References spmatrix_s::baseval, spmatrix_s::dof, spmatrix_s::dofs, spmatrix_s::gNexp, spmatrix_s::loc2glob, and spmatrix_s::n.
Referenced by spm_cspmm(), and spm_cspmv().
◆ c_spmm_build_Btmp()
void c_spmm_build_Btmp ( int nrhs,
const spm_complex32_t * Bloc,
spm_int_t ldbl,
spm_complex32_t ** Bglb,
spm_int_t * ldbg )
static
Parameters
[in]BlocThe local B vector.
[in,out]ldblThe leading dimension of the local B vector.
[out]BglbThe global B vector.
[out]ldbgThe leading dimension of the global B vector.
Definition at line 1012 of file c_spm_matrixvector.c.
References c_spmGatherRHS(), and spmatrix_s::gNexp.
