SpM Handbook 1.3.0
Searching...
No Matches
example_mdof2.c File Reference
Go to the source code of this file.
Detailed Description
Example to show how to use the SPM library with a 1-based constant multi-dof sparse matrix allocated through the library but initialized by the user.
Version
1.3.0
Author
Mathieu Faverge
Tony Delarue
Date
2024-07-09
#include <spm.h>
* @brief Create an IJV symmetric laplacian matrix for a regular cube of
* dimensions (dim1 x dim2 x dim3) and with 1-based values as in Fortran arrays.
static inline void
spm_example_fill_ijv_spm( spm_int_t *colptr,
spm_int_t *rowptr,
double *values,
spm_int_t dim1,
spm_int_t dim2,
spm_int_t dim3,
spm_int_t dof )
spm_int_t l, i, j, k, v, d;
spm_int_t mdim1, mdim2, mdim3;
double alpha = 8.;
double beta = 0.5;
double value;
mdim1 = dim1 - 1;
mdim2 = dim2 - 1;
mdim3 = dim3 - 1;
l = 0;
v = 0;
for( i = 0; i < dim1; i++ )
for( j = 0; j < dim2; j++ )
for( k = 0; k < dim3; k++ )
* Start with the diagonal element connected with its two
* neigbours in the three directions
rowptr[l] = i + dim1 * j + dim1 * dim2 * k + 1;
colptr[l] = i + dim1 * j + dim1 * dim2 * k + 1;
l++;
* Fill the element matrix
value = 6.;
if ( i == 0 ) { value -= 1.; }
if ( i == mdim1 ) { value -= 1.; }
if ( j == 0 ) { value -= 1.; }
if ( j == mdim2 ) { value -= 1.; }
if ( k == 0 ) { value -= 1.; }
if ( k == mdim3 ) { value -= 1.; }
/* Scale by alpha */
value *= alpha;
for( d=0; d<(dof*dof); d++ ) {
values[v] = value;
v++;
/* Add connexions */
if ( i < mdim1 ) {
rowptr[l] = (i+1) + dim1 * j + dim1 * dim2 * k + 1;
l++;
values[v] = - beta;
v++;
if ( j < mdim2 ) {
rowptr[l] = i + dim1 * (j+1) + dim1 * dim2 * k + 1;
l++;
values[v] = - beta;
v++;
if ( k < mdim3 ) {
rowptr[l] = i + dim1 * j + dim1 * dim2 * (k+1) + 1;
l++;
values[v] = - beta;
v++;
assert( l == ((2*(dim1)-1) * dim2 * dim3 + (dim2-1)*dim1*dim3 + dim2*dim1*(dim3-1)) );
* @brief Create a laplacian manually
void
spm_example_create_laplacian( spmatrix_t *spm )
spm_int_t dim1, dim2, dim3, dof;
spm_int_t *colptr;
spm_int_t *rowptr;
double *values;
spm_int_t n, nnz;
dim1 = 6;
dim2 = 6;
dim3 = 6;
dof = 3;
n = dim1 * dim2 * dim3;
nnz = dim1 * dim2 * dim3; /* Diagonal elements */
nnz += (dim1 - 1) * dim2 * dim3; /* Connexions along first axe */
nnz += dim1 * (dim2 - 1) * dim3; /* Connexions along second axe */
nnz += dim1 * dim2 * (dim3 - 1); /* Connexions along third axe */
* Allocate the pointers of the spm.
colptr = malloc( nnz * sizeof(spm_int_t) );
rowptr = malloc( nnz * sizeof(spm_int_t) );
values = malloc( nnz * dof * dof * sizeof(double) );
* Generate the user matrix.
spm_example_fill_ijv_spm( colptr, rowptr, values,
dim1, dim2, dim3, dof );
* Create the associated spm data structure.
spmInit( spm );
* Set the fields according to what we want to generate.
* All non computed fields must be set.
spm->baseval = 1;
spm->fmttype = SpmIJV;
spm->n = n;
spm->nnz = nnz;
spm->dof = dof;
spm->colptr = colptr;
spm->rowptr = rowptr;
spm->values = values;
/* The full matrix is replicated on all nodes */
spm->replicated = 1;
* Update the computed fields.
int main (int argc, char **argv)
spm_int_t nrhs = 10;
double alpha = 2.;
spm_int_t size, ldb, ldx;
double epsilon, norm;
void *x, *b;
int rc = 0;
#if defined(SPM_WITH_MPI)
MPI_Init( &argc, &argv );
#endif
* Create a user made sparse matrix.
spm_example_create_laplacian( &spm );
* Print basic information about the sparse matrix
spmPrintInfo( &spm, stdout );
* Possibly convert the SPM into another format (CSC may be needed for a few routines)
spmConvert( SpmCSC, &spm );
* Compute the frobenius norm of the spm
norm = spmNorm( SpmFrobeniusNorm, &spm );
fprintf( stdout, " || A ||_f: %e\n", norm );
* Scale the sparse matrix.
if ( norm > 0. ) {
spmScal( 1. / norm, &spm );
* Create a random matrix x to test products (multiple right hand side).
* Note that you can get the size to allocate with spm_size_of() that
* returns the size of each value.
ldb = spm.nexp > 1 ? spm.nexp : 1;
ldx = spm.nexp > 1 ? spm.nexp : 1;
size = spm_size_of( spm.flttype ) * spm.nexp * nrhs;
x = malloc( size );
rc = spmGenMat( SpmRhsRndX, nrhs, &spm, &alpha, 24356, x, ldx );
if ( rc != SPM_SUCCESS ) {
free( x );
spmExit( &spm );
return rc;
* Compute b = A * x
b = malloc( size );
spmMatMat( SpmNoTrans, nrhs, 1., &spm, x, ldx, 0., b, ldb );
* The following routines helps to check results obtained out of solvers by
* computing b = b - A * x with a given precision.
if ( (spm.flttype == SpmDouble ) ||
(spm.flttype == SpmComplex64) )
epsilon = 1e-15;
else {
epsilon = 1e-7;
epsilon = epsilon * spm.nnzexp / spm.gN;
rc = spmCheckAxb( epsilon, nrhs, &spm, NULL, 1, b, ldb, x, ldx );
free( x );
free( b );
/* Warning: Free the pointers allocated by the user */
spmExit( &spm );
MPI_Finalize();
#endif
(void)argc;
(void)argv;
return rc;
static size_t spm_size_of(spm_coeftype_t type)
Double datatype that is not converted through precision generator functions.
Definition datatypes.h:209
@ SPM_SUCCESS
Definition const.h:82
@ SpmNoTrans
Definition const.h:155
@ SpmColMajor
Definition const.h:148
@ SpmComplex64
Definition const.h:66
@ SpmDouble
Definition const.h:64
@ SpmSymmetric
Definition const.h:166
@ SpmCSC
Definition const.h:73
@ SpmIJV
Definition const.h:75
@ SpmFrobeniusNorm
Definition const.h:200
spm_coeftype_t flttype
Definition spm.h:68
spm_int_t nexp
Definition spm.h:79
void * values
Definition spm.h:93
spm_int_t nnz
Definition spm.h:76
spm_int_t nnzexp
Definition spm.h:81
spm_int_t * rowptr
Definition spm.h:91
spm_fmttype_t fmttype
Definition spm.h:70
spm_int_t dof
Definition spm.h:83
spm_int_t n
Definition spm.h:74
spm_mtxtype_t mtxtype
Definition spm.h:66
spm_layout_t layout
Definition spm.h:88
spm_int_t baseval
Definition spm.h:72
spm_int_t * colptr
Definition spm.h:90
spm_int_t gN
Definition spm.h:73
int replicated
Definition spm.h:99
void spmExit(spmatrix_t *spm)
Cleanup the spm structure but do not free the spm pointer.
Definition spm.c:234
void spmUpdateComputedFields(spmatrix_t *spm)
Update all the computed fields based on the static values stored.
struct spmatrix_s spmatrix_t
The sparse matrix data structure.
int spmCheckAxb(double eps, spm_int_t nrhs, const spmatrix_t *spm, void *opt_X0, spm_int_t opt_ldx0, void *B, spm_int_t ldb, const void *X, spm_int_t ldx)
Check the backward error, and the forward error if x0 is provided.
Definition spm.c:1434
int spmConvert(int ofmttype, spmatrix_t *ospm)
Convert the storage format of the spm.
Definition spm.c:429
int spmMatMat(spm_trans_t trans, spm_int_t n, double alpha, const spmatrix_t *A, const void *B, spm_int_t ldb, double beta, void *C, spm_int_t ldc)
Compute a matrix-matrix product.
Definition spm.c:1338
void spmScal(double alpha, spmatrix_t *spm)
Scale the spm.
Definition spm.c:1492
double spmNorm(spm_normtype_t ntype, const spmatrix_t *spm)
Compute the norm of the spm.
Definition spm.c:525
void spmInit(spmatrix_t *spm)
Init the spm structure.
Definition spm.c:156
int spm_int_t
The main integer datatype used in spm arrays.
Definition datatypes.h:70
int spmGenMat(spm_rhstype_t type, spm_int_t nrhs, const spmatrix_t *spm, void *alpha, unsigned long long int seed, void *A, spm_int_t lda)
Generate a set of vectors associated to a given matrix.
Definition spm.c:1743
void spmPrintInfo(const spmatrix_t *spm, FILE *f)
Print basic informations about the spm matrix into a given stream.
Definition spm.c:1037
Definition in file example_mdof2.c.
