SpM Handbook 1.3.0
#include <stdlib.h>#include <assert.h>#include <stdio.h>#include "spm/config.h"#include "spm/const.h"#include "spm/datatypes.h"#include "spm/mpi.h"#include "spm/z_spm.h"#include "spm/c_spm.h"#include "spm/d_spm.h"#include "spm/s_spm.h"#include "spm/p_spm.h"Go to the source code of this file.
Data Structures | |
| struct | spmatrix_s |
| The sparse matrix data structure. More... | |
Typedefs | |
| typedef struct spmatrix_s | spmatrix_t |
| The sparse matrix data structure. | |
Functions | |
| int | spmBlasGetNumThreads (void) |
| Return the current number of threads used for blas calls. | |
| int | spmBlasSetNumThreads (int nt) |
| Set the number of threads for blas calls (BLIS, MKL, OpenBLAS) and return the previous number of blas threads. | |
| int | spmBlasSetNumThreadsOne (void) |
| Set the number of threads for blas calls (BLIS, MKL, OpenBLAS) to 1 and return the previous number of blas threads. | |
SPM basic subroutines | |
| void | spmInit (spmatrix_t *spm) |
| Init the spm structure. | |
| void | spmInitDist (spmatrix_t *spm, SPM_Comm comm) |
| Init the spm structure with a specific communicator. | |
| void | spmAlloc (spmatrix_t *spm) |
| Allocate the arrays of an spm structure. | |
| void | spmExit (spmatrix_t *spm) |
| Cleanup the spm structure but do not free the spm pointer. | |
| void | spmCopy (const spmatrix_t *spm, spmatrix_t *newspm) |
| Create a copy of the spm. | |
| void | spmBase (spmatrix_t *spm, int baseval) |
| Rebase the arrays of the spm to the given value. | |
| spm_int_t | spmFindBase (const spmatrix_t *spm) |
| Search the base used in the spm structure. | |
| spm_int_t | spmGetDegree (const spmatrix_t *spm) |
| int | spmConvert (int ofmttype, spmatrix_t *spm) |
| Convert the storage format of the spm. | |
| void | spmUpdateComputedFields (spmatrix_t *spm) |
| Update all the computed fields based on the static values stored. | |
| void | spmGenFakeValues (spmatrix_t *spm) |
Generate the fake values array such that ![]() | |
SPM distribution subroutines | |
| int | spmScatter (spmatrix_t *newspm, int root, const spmatrix_t *oldspm, spm_int_t n, const spm_int_t *loc2glob, int distByColumn, SPM_Comm comm) |
| Scatter the SPM thanks to loc2glob. | |
| int | spmGather (const spmatrix_t *spm_scattered, int root, spmatrix_t *opt_spm_gathered) |
| Gather a distributed Sparse Matrix on a single node. | |
| int | spmGatherInPlace (spmatrix_t *spm) |
| This routine performs a allgather of a distributed spm in place. | |
| int | spmRedistribute (const spmatrix_t *spm, spm_int_t new_n, const spm_int_t *newl2g, spmatrix_t *newspm) |
| Create a copy of a given SPM with a new distribution corresponding to the given loc2glob array. | |
SPM BLAS subroutines | |
| double | spmNorm (spm_normtype_t ntype, const spmatrix_t *spm) |
| Compute the norm of the spm. | |
| double | spmNormVec (spm_normtype_t ntype, const spmatrix_t *spm, const void *x, spm_int_t inc) |
| double | spmNormMat (spm_normtype_t ntype, const spmatrix_t *spm, spm_int_t n, const void *A, spm_int_t lda) |
| int | spmMatVec (spm_trans_t trans, double alpha, const spmatrix_t *spm, const void *x, double beta, void *y) |
| Compute a matrix-vector product. | |
| int | spmMatMat (spm_trans_t trans, spm_int_t n, double alpha, const spmatrix_t *A, const void *B, spm_int_t ldb, double beta, void *C, spm_int_t ldc) |
| Compute a matrix-matrix product. | |
| void | spmScal (double alpha, spmatrix_t *spm) |
| Scale the spm. | |
| void | spmScalVec (double alpha, const spmatrix_t *spm, void *x, spm_int_t incx) |
| Scale a vector associated to a sparse matrix. Deprecated function replaced by spmScalVec() or spmScalMat(). | |
| void | spmScalMat (double alpha, const spmatrix_t *spm, spm_int_t n, void *A, spm_int_t lda) |
| Scale a matrix associated to a sparse matrix. | |
| void | spmScalMatrix (double alpha, spmatrix_t *spm) |
| Scale the spm. | |
| void | spmScalVector (spm_coeftype_t flt, double alpha, spm_int_t n, void *x, spm_int_t incx) |
| Scale a vector according to the spm type. | |
SPM subroutines to check format | |
| int | spmSort (spmatrix_t *spm) |
| Sort the subarray of edges of each vertex. | |
| spm_int_t | spmMergeDuplicate (spmatrix_t *spm) |
| Merge multiple entries in a spm by summing their values together. | |
| spm_int_t | spmSymmetrize (spmatrix_t *spm) |
| Symmetrize the pattern of the spm. | |
| int | spmCheckAndCorrect (const spmatrix_t *spm_in, spmatrix_t *spm_out) |
| Check the correctness of a spm. | |
SPM subroutines to check factorization/solve | |
| int | spmGenMat (spm_rhstype_t type, spm_int_t nrhs, const spmatrix_t *spm, void *alpha, unsigned long long int seed, void *A, spm_int_t lda) |
| Generate a set of vectors associated to a given matrix. | |
| int | spmGenVec (spm_rhstype_t type, const spmatrix_t *spm, void *alpha, unsigned long long int seed, void *x, spm_int_t incx) |
| Generate a vector associated to a given matrix. | |
| int | spmGenRHS (spm_rhstype_t type, spm_int_t nrhs, const spmatrix_t *spm, void *x, spm_int_t ldx, void *b, spm_int_t ldb) |
| Generate right hand side vectors associated to a given matrix. | |
| int | spmCheckAxb (double eps, spm_int_t nrhs, const spmatrix_t *spm, void *x0, spm_int_t ldx0, void *b, spm_int_t ldb, const void *x, spm_int_t ldx) |
| Check the backward error, and the forward error if x0 is provided. | |
SPM subroutines to manipulate RHS | |
| int | spmExtractLocalRHS (spm_int_t nrhs, const spmatrix_t *spm, const void *bglob, spm_int_t ldbg, void *bloc, spm_int_t ldbl) |
| Stores the local values of a global RHS in the local one thanks to spm distribution. | |
| int | spmReduceRHS (spm_int_t nrhs, const spmatrix_t *spm, void *bglob, spm_int_t ldbg, void *bloc, spm_int_t ldbl) |
| Reduce an RHS thanks to spm distribution. | |
| int | spmGatherRHS (spm_int_t nrhs, const spmatrix_t *spm, const void *bloc, spm_int_t ldbl, int root, void *bglob, spm_int_t ldbg) |
| Gather an RHS thanks to spm distribution. | |
SPM subroutines to manipulate integers arrays | |
| void | spmIntConvert (spm_int_t n, const int *input, spm_int_t *output) |
| Convert integer array to spm_int_t format. | |
| void | spmIntSort1Asc1 (void *const pbase, spm_int_t n) |
| void | spmIntSort2Asc1 (void *const pbase, spm_int_t n) |
| void | spmIntSort2Asc2 (void *const pbase, spm_int_t n) |
| void | spmIntMSortIntAsc (void **const pbase, spm_int_t n) |
SPM IO subroutines | |
| int | spmLoadDist (spmatrix_t *spm, const char *filename, SPM_Comm comm) |
| Load the spm structure from a file (internal format). | |
| int | spmLoad (spmatrix_t *spm, const char *filename) |
| int | spmSave (const spmatrix_t *spm, const char *filename) |
| Save the spm structure into a file (internal format). | |
SPM driver | |
| int | spmReadDriver (spm_driver_t driver, const char *filename, spmatrix_t *spm) |
| Import a matrix file into a spm structure. | |
| int | spmReadDriverDist (spm_driver_t driver, const char *filename, spmatrix_t *spm, SPM_Comm comm) |
| Import a matrix file into an spm structure for a specific communicator. | |
| int | spmParseLaplacianInfo (const char *filename, spm_coeftype_t *flttype, spm_int_t *dim1, spm_int_t *dim2, spm_int_t *dim3, double *alpha, double *beta, spm_int_t *dof) |
| Parse information given through the filename string to configure the laplacian matrix to generate. | |
SPM debug subroutines | |
| void | spm2Dense (const spmatrix_t *spm, void *A) |
| Convert the spm matrix into a dense matrix for test purpose. | |
| void | spmPrint (const spmatrix_t *spm, FILE *stream) |
| Print an spm matrix into into a given file. | |
| void | spmPrintRHS (const spmatrix_t *spm, int nrhs, const void *x, spm_int_t ldx, FILE *stream) |
| Print a set of vector associated to an spm matrix. | |
| void | spmPrintInfo (const spmatrix_t *spm, FILE *stream) |
| Print basic informations about the spm matrix into a given stream. | |
| void | spmExpand (const spmatrix_t *spm_in, spmatrix_t *spm_out) |
| Expand a multi-dof spm matrix into an spm with constant dof set to 1. | |
| int | spmDofExtend (const spmatrix_t *spm, const int type, const int dof, spmatrix_t *newspm) |
| Generate a random multidof spm from a given spm (with dof=1). | |
SPM subroutines to detect diagonal zeros | |
| int | spmGetDiagonalZeros (const spmatrix_t *spm, spm_int_t *zeros_n, spm_int_t **zeros_list) |
| Detect unknowns whose diagonal entry is zero or absent. | |
SPM dev printing subroutines | |
| #define | p_spmPrintElt(f, i, j, A) |
| Subroutines to print one element of an spm structure. | |
| static void | z_spmPrintElt (FILE *f, spm_int_t i, spm_int_t j, spm_complex64_t A) |
| static void | c_spmPrintElt (FILE *f, spm_int_t i, spm_int_t j, spm_complex32_t A) |
| static void | d_spmPrintElt (FILE *f, spm_int_t i, spm_int_t j, double A) |
| static void | s_spmPrintElt (FILE *f, spm_int_t i, spm_int_t j, float A) |
SParse Matrix package header.
Definition in file spm.h.
| #define p_spmPrintElt | ( | f, | |
| i, | |||
| j, | |||
| A ) |
| [in] | f | Pointer to the file |
| [in] | i | Row index of the element |
| [in] | j | Column index of the element |
| [in] | A | Value of the element A|i,j] |
Double complex case
Pattern case
Definition at line 345 of file spm.h.
Referenced by p_spm_print_elt_gen_col(), p_spm_print_elt_gen_row(), p_spm_print_elt_sym_diag(), and p_spmPrintRHS().
static |
Double complex case
Single complex case
Definition at line 317 of file spm.h.
Referenced by c_spm_print_elt_gen_col(), c_spm_print_elt_gen_row(), c_spm_print_elt_sym_diag(), c_spmDensePrint(), and c_spmPrintRHS().
Double complex case
Double real case
Definition at line 326 of file spm.h.
Referenced by d_spm_print_elt_gen_col(), d_spm_print_elt_gen_row(), d_spm_print_elt_sym_diag(), d_spmDensePrint(), and d_spmPrintRHS().
Double complex case
Single real case
Definition at line 335 of file spm.h.
Referenced by s_spm_print_elt_gen_col(), s_spm_print_elt_gen_row(), s_spm_print_elt_sym_diag(), s_spmDensePrint(), and s_spmPrintRHS().
| int spmBlasGetNumThreads | ( | void | ) |
Definition at line 2293 of file spm.c.
Referenced by spmBlasSetNumThreads().
| int spmBlasSetNumThreads | ( | int | nt | ) |
| [in] | nt | Number of threads. |
Definition at line 2321 of file spm.c.
References spmBlasGetNumThreads().
Referenced by spmBlasSetNumThreadsOne().
| int spmBlasSetNumThreadsOne | ( | void | ) |
Definition at line 2347 of file spm.c.
References spmBlasSetNumThreads().
