SpM Handbook 1.2.4
Searching...
No Matches
d_spm_genmat.c File Reference
#include "common.h"
#include <cblas.h>
#include <lapacke.h>
Go to the source code of this file.
Functions
static unsigned long long int Rnd64_jump (unsigned long long int n, unsigned long long int seed)
 Random generator from the HPL library.
static void d_updateRndVal (double scale, double *val, unsigned long long int *ran)
 Generate a value of the RHS.
int d_spmRhsGenRndShm (const spmatrix_t *spm, double scale, spm_int_t n, double *A, spm_int_t lda, int shift, unsigned long long int seed)
 Generate a set of vectors of random values in shared memory.
static int d_spm_rhs_dist_genRnd_csx (const spmatrix_t *spm, double alpha, spm_int_t n, double *A, spm_int_t lda, int shift, unsigned long long int seed)
 Generate a set of vectors of random values in distributed memory for CSX format.
static int d_spm_rhs_dist_genRnd_ijv (const spmatrix_t *spm, double alpha, spm_int_t n, double *A, spm_int_t lda, int shift, unsigned long long int seed)
 Generate a set of vectors of random values in distributed memory for IJV format.
int d_spmRhsGenRndDist (const spmatrix_t *spm, double alpha, spm_int_t n, double *A, spm_int_t lda, int shift, unsigned long long int seed)
 Generate a set of vectors of random values in distributed memory.
static int d_spmRhsGenOne (const spmatrix_t *spm, double alpha, spm_int_t n, double *A, spm_int_t lda)
 Generate a set of vectors of constant values.
static int d_spm_rhs_genI_csx (const spmatrix_t *spm, double alpha, spm_int_t n, double *A, spm_int_t lda)
 Generate a set of vectors x[i] = alpha * ( i [+ i* I ] ) for CSC format.
static int d_spm_rhs_genI_ijv (const spmatrix_t *spm, double alpha, spm_int_t n, double *A, spm_int_t lda)
 Generate a set of vectors x[i] = alpha * ( i [+ i* I ] ) for IJV format.
static int d_spmRhsGenI (const spmatrix_t *spm, double alpha, spm_int_t n, double *A, spm_int_t lda)
 Generate a set of vectors x[i] = alpha * ( i [+ i* I ] ).
int d_spmGenMat (spm_rhstype_t type, int nrhs, const spmatrix_t *spm, void *alphaptr, unsigned long long int seed, void *A, int lda)
 Generate nrhs right hand side vectors associated to a given matrix to test a problem with a solver.
Detailed Description
SParse Matrix package matrix generators.
Version
1.2.4
Author
Mathieu Faverge
Tony Delarue
Alycia Lisito
Date
2024-06-25
Generated arithmetic file from /builds/2mk6rsew/0/fpruvost/spm/src/z_spm_genmat.c, normal z -> d, Fri Nov 29 11:34:29 2024
Definition in file d_spm_genmat.c.
Function Documentation
◆ Rnd64_jump()
static unsigned long long int Rnd64_jump ( unsigned long long int  n,
static
Parameters
[in]nNumber of elements to jump over in the generator cycle.
[in]seed
Return values
arandom integer value
Definition at line 49 of file d_spm_genmat.c.
Referenced by d_spm_rhs_dist_genRnd_csx(), d_spm_rhs_dist_genRnd_ijv(), and d_spmRhsGenRndShm().
◆ d_spm_rhs_dist_genRnd_csx()
static int d_spm_rhs_dist_genRnd_csx ( const spmatrix_t spm,
double  alpha,
spm_int_t  n,
double *  A,
spm_int_t  lda,
int  shift,
static
Parameters
[in]spmThe sparse matrix associated to the right hand side.
[in]alphaScaling factor for each value of the vector.
[in]nThe number of columns in A. n >= 0.
[in,out]AOn entry, the lda-by-n matrix to be initialized. On exit, the matrix initialized.
[in]ldaThe leading dimension of the matrix A. lda >= max(1,spm->nexp).
[in]shiftThe initial shift in the random sequence.
[in]seedThe seed used for random generation. Must be the same for all tiles initialized with this routine.
Return values
SPM_SUCCESSon success
SPM_ERR_BADPARAMETERif the provided spm is incorrect
Definition at line 215 of file d_spm_genmat.c.
References spmatrix_s::baseval, d_updateRndVal(), spmatrix_s::dof, spmatrix_s::dofs, spmatrix_s::gNexp, spmatrix_s::loc2glob, spmatrix_s::n, spmatrix_s::replicated, Rnd64_jump(), and SPM_SUCCESS.
Referenced by d_spmRhsGenRndDist().
◆ d_spm_rhs_dist_genRnd_ijv()
static int d_spm_rhs_dist_genRnd_ijv ( const spmatrix_t spm,
double  alpha,
spm_int_t  n,
double *  A,
spm_int_t  lda,
int  shift,
static
Warning
The matrix has to be sorted by column or by row.
Parameters
Return values
Definition at line 303 of file d_spm_genmat.c.
References spmatrix_s::baseval, spmatrix_s::colptr, d_updateRndVal(), spmatrix_s::dof, spmatrix_s::dofs, spmatrix_s::gNexp, spmatrix_s::nnz, Rnd64_jump(), spmatrix_s::rowptr, SPM_ERR_BADPARAMETER, spm_get_distribution(), SPM_SUCCESS, SpmDistByColumn, and SpmDistByRow.
◆ d_spm_rhs_genI_csx()
static int d_spm_rhs_genI_csx ( const spmatrix_t spm,
double  alpha,
spm_int_t  n,
double *  A,
spm_int_t  lda
static
Parameters
Return values
Definition at line 529 of file d_spm_genmat.c.
References spmatrix_s::baseval, spmatrix_s::dof, spmatrix_s::dofs, spmatrix_s::loc2glob, spmatrix_s::n, spmatrix_s::nexp, spmatrix_s::replicated, and SPM_SUCCESS.
Referenced by d_spmRhsGenI().
◆ d_spm_rhs_genI_ijv()
static int d_spm_rhs_genI_ijv ( const spmatrix_t spm,
double  alpha,
spm_int_t  n,
double *  A,
spm_int_t  lda
static
Warning
Parameters
Return values
If the spm is global, we have to know which vertice is sorted
Definition at line 607 of file d_spm_genmat.c.
References spmatrix_s::baseval, spmatrix_s::colptr, spmatrix_s::dof, spmatrix_s::dofs, spmatrix_s::nexp, spmatrix_s::nnz, spmatrix_s::rowptr, SPM_ERR_BADPARAMETER, spm_get_distribution(), SPM_SUCCESS, SpmDistByColumn, and SpmDistByRow.
