Example to show how to use the SPM library with a variadic 0-based multi-dof sparse matrix allocated through the library but initialized by the user.
static inline void
mdim1 = dim1 - 1;
mdim2 = dim2 - 1;
mdim3 = dim3 - 1;
n = 0;
nnz = 0;
d = 0;
for( i = 0; i < dim1; i++ )
for( j = 0; j < dim2; j++ )
for( k = 0; k < dim3; k++ )
spm->
rowptr[nnz] = i + dim1 * j + dim1 * dim2 * k;
spm->
colptr[nnz] = i + dim1 * j + dim1 * dim2 * k;
nnz++;
n++;
d += (( i + j + k ) % 3) + 1;
if ( i < mdim1 ) {
spm->
rowptr[nnz] = (i+1) + dim1 * j + dim1 * dim2 * k;
spm->
nnz++;
if ( j < mdim2 ) {
spm->
rowptr[nnz] = i + dim1 * (j+1) + dim1 * dim2 * k;
spm->
nnz++;
if ( k < mdim3 ) {
spm->
rowptr[nnz] = i + dim1 * j + dim1 * dim2 * (k+1);
spm->
nnz++;
assert( nnz == ((2*(dim1)-1) * dim2 * dim3 + (dim2-1)*dim1*dim3 + dim2*dim1*(dim3-1)) );
static inline void
double alpha = 8.;
double beta = 0.5;
double value;
mdim1 = dim1 - 1;
mdim2 = dim2 - 1;
mdim3 = dim3 - 1;
v = 0;
for( l=0; l<spm->
nnz; l++ )
k = l / ( dim1 * dim2 );
j = (l % ( dim1 * dim2 )) / dim1;
i = l % dim1;
dofcol = spm->
dofs[ col+1 ] - spm->
dofs[ col ];
dofrow = spm->
dofs[ row+1 ] - spm->
dofs[ row ];
if ( col == row ) {
value = 6.;
if ( i == 0 ) { value -= 1.; }
if ( i == mdim1 ) { value -= 1.; }
if ( j == 0 ) { value -= 1.; }
if ( j == mdim2 ) { value -= 1.; }
if ( k == 0 ) { value -= 1.; }
if ( k == mdim3 ) { value -= 1.; }
value *= alpha;
else {
value = - beta;
for ( n=0; n<dofcol; n++ ) {
for ( m=0; m<dofrow; m++ ) {
values[v] = value;
v++;
void
dim1 = 6;
dim2 = 6;
dim3 = 6;
spm->
n = dim1 * dim2 * dim3;
spm->
nnz = dim1 * dim2 * dim3;
spm->
nnz += (dim1 - 1) * dim2 * dim3;
spm->
nnz += dim1 * (dim2 - 1) * dim3;
spm->
nnz += dim1 * dim2 * (dim3 - 1);
spm_example_fill_ijv_struct( spm, dim1, dim2, dim3 );
spm_example_fill_ijv_values( spm, dim1, dim2, dim3 );
int main( int argc, char **argv )
double alpha = 2.;
double epsilon, norm;
void *x, *b;
int rc = 0;
#if defined(SPM_WITH_MPI)
MPI_Init( &argc, &argv );
#endif
spm_example_create_laplacian( &spm );
fprintf( stdout, " || A ||_f: %e\n", norm );
if ( norm > 0. ) {
x = malloc( size );
rc =
spmGenMat( SpmRhsRndX, nrhs, &spm, &alpha, 24356, x, ldx );
free( x );
return rc;
b = malloc( size );
epsilon = 1e-15;
else {
epsilon = 1e-7;
epsilon = epsilon * spm.
nnzexp / spm.
gN;
rc =
spmCheckAxb( epsilon, nrhs, &spm, NULL, 1, b, ldb, x, ldx );
free( x );
free( b );
MPI_Finalize();
#endif
(void)argc;
(void)argv;
return rc;
static size_t spm_size_of(spm_coeftype_t type)
Double datatype that is not converted through precision generator functions.
void spmAlloc(spmatrix_t *spm)
Allocate the arrays of an spm structure.
void spmExit(spmatrix_t *spm)
Cleanup the spm structure but do not free the spm pointer.
void spmUpdateComputedFields(spmatrix_t *spm)
Update all the computed fields based on the static values stored.
struct spmatrix_s spmatrix_t
The sparse matrix data structure.
int spmCheckAxb(double eps, spm_int_t nrhs, const spmatrix_t *spm, void *opt_X0, spm_int_t opt_ldx0, void *B, spm_int_t ldb, const void *X, spm_int_t ldx)
Check the backward error, and the forward error if x0 is provided.
int spmConvert(int ofmttype, spmatrix_t *ospm)
Convert the storage format of the spm.
int spmMatMat(spm_trans_t trans, spm_int_t n, double alpha, const spmatrix_t *A, const void *B, spm_int_t ldb, double beta, void *C, spm_int_t ldc)
Compute a matrix-matrix product.
void spmScal(double alpha, spmatrix_t *spm)
Scale the spm.
double spmNorm(spm_normtype_t ntype, const spmatrix_t *spm)
Compute the norm of the spm.
void spmInit(spmatrix_t *spm)
Init the spm structure.
int spm_int_t
The main integer datatype used in spm arrays.
int spmGenMat(spm_rhstype_t type, spm_int_t nrhs, const spmatrix_t *spm, void *alpha, unsigned long long int seed, void *A, spm_int_t lda)
Generate a set of vectors associated to a given matrix.
void spmPrintInfo(const spmatrix_t *spm, FILE *f)
Print basic informations about the spm matrix into a given stream.
