SpM Handbook 1.2.4
#include "common.h"
#include <lapacke.h>
#include <cblas.h>
#include "frobeniusupdate.h"
Go to the source code of this file.
#define | LAPACKE_classq_work(_n_, _X_, _incx_, _scale_, _sumsq_) __spm_classq( (_n_), (_X_), (_incx_), (_scale_), (_sumsq_) ) |
TODO. | |
static int | __spm_classq (spm_int_t n, spm_complex32_t *x, spm_int_t incx, float *scale, float *sumsq) |
Updates the values scale and sumsq such that. | |
static void | c_spm_frobenius_elt_sym_diag (spm_int_t dofs, const float *valptr, float *data) |
Compute the Frobenius norm of a diagonal element within a symmetric/hermitian matrix with column/row major storage. | |
static void | c_spm_frobenius_elt_sym_offd (spm_int_t nbelts, const float *valptr, float *data) |
Compute the Frobenius norm of an off-diagonal element matrix in the symmetric/hermitian case. | |
static void | c_spm_frobenius_elt_sym (spm_int_t row, spm_int_t dofi, spm_int_t col, spm_int_t dofj, const spm_complex32_t *valptr, float *data) |
Compute the Frobenius norm of any element matrix in the symmetric/hermitian case. | |
static void | c_spmFrobeniusNorm_csc (const spmatrix_t *spm, float *data) |
Compute the Frobenius norm of a symmetrix/hermitian CSC matrix. | |
static void | c_spmFrobeniusNorm_csr (const spmatrix_t *spm, float *data) |
Compute the Frobenius norm of a symmetrix/hermitian CSR matrix. | |
static void | c_spmFrobeniusNorm_ijv (const spmatrix_t *spm, float *data) |
Compute the Frobenius norm of a symmetrix/hermitian IJV matrix. | |
float | c_spmFrobeniusNorm (const spmatrix_t *spm) |
Compute the Frobenius norm of the given spm structure. | |
float | c_spmMaxNorm (const spmatrix_t *spm) |
Compute the Max norm of the given spm structure. | |
static void | c_spm_oneinf_elt_sym_diag (spm_int_t row, spm_int_t dofi, const spm_complex32_t *valptr, float *sumtab) |
Compute the sum array for the one/inf norms of a diagonal element within a symmetric/hermitian matrix with column/row major storage. | |
static void | c_spm_oneinf_elt_gen_A (spm_int_t dofi, spm_int_t dofj, const spm_complex32_t *valptr, float *sumtab) |
Compute the sum array for the one/inf norms of a general element. | |
static void | c_spm_oneinf_elt_gen_B (spm_int_t dofi, spm_int_t dofj, const spm_complex32_t *valptr, float *sumtab) |
static void | c_spm_oneinf_elt_gen_AB (spm_int_t row, spm_int_t dofi, spm_int_t col, spm_int_t dofj, const spm_complex32_t *valptr, float *sumtab) |
Compute the sum array for both the one and inf norms for the off-diagonal elements of symmetric/hermitian element matrices. | |
static void | c_spm_oneinf_elt_gen (spm_layout_t layout, spm_int_t row, spm_int_t dofi, spm_int_t col, spm_int_t dofj, const spm_complex32_t *valptr, spm_normtype_t ntype, float *sumtab) |
Compute the sum array for the one and inf norms of a general element. | |
static void | c_spm_oneinf_elt_sym_offd (spm_layout_t layout, spm_int_t row, spm_int_t dofi, spm_int_t col, spm_int_t dofj, const spm_complex32_t *valptr, float *sumtab) |
Compute the sum array for both the one and inf norms for the off-diagonal elements of symmetric/hermitian element matrices in either column or row major layout. | |
static void | c_spm_oneinf_elt (spm_mtxtype_t mtxtype, spm_layout_t layout, spm_int_t row, spm_int_t dofi, spm_int_t col, spm_int_t dofj, const spm_complex32_t *valptr, spm_normtype_t ntype, float *sumtab) |
Compute the sum array for the one/inf norm for an element matrix. | |
static void | c_spmOneInfNorm_csc (spm_normtype_t ntype, const spmatrix_t *spm, float *sumtab) |
Compute the one/inf norm of an spm CSC structure. | |
static void | c_spmOneInfNorm_csr (spm_normtype_t ntype, const spmatrix_t *spm, float *sumtab) |
Compute the one/inf norm of an spm CSR structure. | |
static void | c_spmOneInfNorm_ijv (spm_normtype_t ntype, const spmatrix_t *spm, float *sumtab) |
Compute the one/inf norm of an spm IJV structure. | |
static float | c_spmOneInfNorm (spm_normtype_t ntype, const spmatrix_t *spm) |
Compute the one/inf norm of the given spm structure given by the maximum row sum. | |
float | c_spmNorm (spm_normtype_t ntype, const spmatrix_t *spm) |
Compute the norm of an spm matrix. | |
float | c_spmNormMat (spm_normtype_t ntype, const spmatrix_t *spm, spm_int_t n, const spm_complex32_t *A, spm_int_t lda) |
Compute the norm of a dense matrix that follows the distribution of an spm matrix. | |
SParse Matrix package norm routine.
Definition in file c_spm_norm.c.
#define LAPACKE_classq_work | ( | _n_, | |
_X_, | |||
_incx_, | |||
_scale_, | |||
_sumsq_ | |||
) | __spm_classq( (_n_), (_X_), (_incx_), (_scale_), (_sumsq_) ) |
TODO.
Definition at line 88 of file c_spm_norm.c.
static |
( scale**2 )*sumsq = x( 1 )**2 +...+ x( n )**2 + ( scale**2 )*sumsq,
This routine is inspired from LAPACK classq function.
[in] | n | The number of elements in the vector |
[in] | x | The vector of size abs(n * incx) |
[in] | incx | The increment between two elements in the vector x. |
[in,out] | scale | On entry, the former scale On exit, the update scale to take into account the value |
[in,out] | sumsq | On entry, the former sumsq On exit, the update sumsq to take into account the value |
Definition at line 63 of file c_spm_norm.c.
static |
Note that column major is using the low triangular part only of the diagonal element matrices, and row major, by symmetry, is using only the upper triangular part.
The comments in the code are made for column major storage.
[in] | dofs | TODO |
[in] | valptr | TODO |
[in,out] | data | TODO |
Definition at line 152 of file c_spm_norm.c.
Referenced by c_spm_frobenius_elt_sym().
static |
[in] | nbelts | TODO |
[in,out] | data |
Definition at line 206 of file c_spm_norm.c.
static |
[in] | row | TODO |
[in] | dofi | TODO |
[in] | col | TODO |
[in] | dofj | TODO |
Definition at line 252 of file c_spm_norm.c.
References c_spm_frobenius_elt_sym_diag(), and c_spm_frobenius_elt_sym_offd().
Referenced by c_spmFrobeniusNorm_csc(), c_spmFrobeniusNorm_csr(), and c_spmFrobeniusNorm_ijv().
static |
[in] | spm | The spm from which the norm need to be computed. |
Definition at line 283 of file c_spm_norm.c.
References spmatrix_s::baseval, c_spm_frobenius_elt_sym(), spmatrix_s::colptr, spmatrix_s::dof, spmatrix_s::dofs, spmatrix_s::flttype, spmatrix_s::fmttype, spmatrix_s::loc2glob, spmatrix_s::n, spmatrix_s::replicated, spmatrix_s::rowptr, SpmComplex32, SpmCSC, and spmatrix_s::values.
Referenced by c_spmFrobeniusNorm().
static |
Definition at line 350 of file c_spm_norm.c.
References spmatrix_s::baseval, c_spm_frobenius_elt_sym(), spmatrix_s::colptr, spmatrix_s::dof, spmatrix_s::dofs, spmatrix_s::flttype, spmatrix_s::fmttype, spmatrix_s::loc2glob, spmatrix_s::n, spmatrix_s::replicated, spmatrix_s::rowptr, SpmComplex32, SpmCSR, and spmatrix_s::values.
static |
Definition at line 418 of file c_spm_norm.c.
References spmatrix_s::baseval, c_spm_frobenius_elt_sym(), spmatrix_s::colptr, spmatrix_s::dof, spmatrix_s::dofs, spmatrix_s::flttype, spmatrix_s::fmttype, spmatrix_s::nnz, spmatrix_s::rowptr, SpmComplex32, SpmIJV, and spmatrix_s::values.
float c_spmFrobeniusNorm | ( | const spmatrix_t * | spm | ) |
||A|| = sqrtf( sum( a_ij ^ 2 ) )
Definition at line 480 of file c_spm_norm.c.
References c_spmFrobeniusNorm_csc(), c_spmFrobeniusNorm_csr(), c_spmFrobeniusNorm_ijv(), spmatrix_s::clustnbr, spmatrix_s::comm, spmatrix_s::fmttype, spmatrix_s::mtxtype, spmatrix_s::nnzexp, spmatrix_s::replicated, SpmCSC, SpmCSR, SpmGeneral, SpmIJV, and spmatrix_s::values.
Referenced by c_spmNorm().
float c_spmMaxNorm | ( | const spmatrix_t * | spm | ) |
||A|| = max( abs(a_ij) )
Definition at line 543 of file c_spm_norm.c.
References spmatrix_s::clustnbr, spmatrix_s::comm, spmatrix_s::nnzexp, spmatrix_s::replicated, and spmatrix_s::values.
static |
[in] | row | TODO |
[in,out] | sumtab | TODO |
Definition at line 591 of file c_spm_norm.c.
Referenced by c_spm_oneinf_elt().
static |
We can observe two cases A and B;
| | | | | | |________| | | | | | | |A| OR |________| |B| |__|__|__| |_| |________| |_|
|___B____| |___A____|
| One Norm | Inf norm |
----------—+-------—+-------—+ Column Major | B | A | ----------—+-------—+-------—+ Row Major | A | B | ----------—+-------—+-------—+
Definition at line 659 of file c_spm_norm.c.
Referenced by c_spm_oneinf_elt_gen().
static |
Definition at line 698 of file c_spm_norm.c.
static |
[in] | row | TODO |
[in] | col | TODO |
Definition at line 744 of file c_spm_norm.c.
Referenced by c_spm_oneinf_elt_sym_offd().
static |
[in] | layout | TODO |
[in] | row | TODO |
[in] | col | TODO |
[in] | ntype | TODO |
Definition at line 799 of file c_spm_norm.c.
References c_spm_oneinf_elt_gen_A(), c_spm_oneinf_elt_gen_B(), SpmColMajor, SpmInfNorm, and SpmOneNorm.
static |
[in] | row | TODO |
[in] | col | TODO |
Definition at line 860 of file c_spm_norm.c.
References c_spm_oneinf_elt_gen_AB(), and SpmColMajor.
static |
[in] | mtxtype | TODO |
[in] | row | TODO |
[in] | col | TODO |
Definition at line 912 of file c_spm_norm.c.
References c_spm_oneinf_elt_gen(), c_spm_oneinf_elt_sym_diag(), c_spm_oneinf_elt_sym_offd(), and SpmGeneral.
Referenced by c_spmOneInfNorm_csc(), c_spmOneInfNorm_csr(), and c_spmOneInfNorm_ijv().
static |
[in] | spm | TODO |
Definition at line 953 of file c_spm_norm.c.
References spmatrix_s::baseval, c_spm_oneinf_elt(), spmatrix_s::colptr, spmatrix_s::dof, spmatrix_s::dofs, spmatrix_s::layout, spmatrix_s::loc2glob, spmatrix_s::mtxtype, spmatrix_s::n, spmatrix_s::replicated, spmatrix_s::rowptr, and spmatrix_s::values.
Referenced by c_spmOneInfNorm().
static |
[in] | spm | TODO |
Definition at line 1019 of file c_spm_norm.c.
static |
[in] | spm | TODO |
Definition at line 1085 of file c_spm_norm.c.
References spmatrix_s::baseval, c_spm_oneinf_elt(), spmatrix_s::colptr, spmatrix_s::dof, spmatrix_s::dofs, spmatrix_s::layout, spmatrix_s::mtxtype, spmatrix_s::nnz, spmatrix_s::rowptr, and spmatrix_s::values.
static |
[in] | ntype | The type of norm to compute. |
Definition at line 1149 of file c_spm_norm.c.
References c_spmOneInfNorm_csc(), c_spmOneInfNorm_csr(), c_spmOneInfNorm_ijv(), spmatrix_s::clustnbr, spmatrix_s::comm, spmatrix_s::fmttype, spmatrix_s::gNexp, spmatrix_s::replicated, SpmCSC, SpmCSR, and SpmIJV.
