SpM Handbook 1.3.0
Searching...
No Matches
Spm_dev_norm
Norm computation routines. More...
file  s_spm_norm.c
file  d_spm_norm.c
file  c_spm_norm.c
file  z_spm_norm.c
Functions
double z_spmNorm (spm_normtype_t ntype, const spmatrix_t *spm)
 Compute the norm of an spm matrix.
double z_spmNormMat (spm_normtype_t ntype, const spmatrix_t *spm, spm_int_t n, const spm_complex64_t *A, spm_int_t lda)
 Compute the norm of a dense matrix that follows the distribution of an spm matrix.
float c_spmNorm (spm_normtype_t ntype, const spmatrix_t *spm)
float c_spmNormMat (spm_normtype_t ntype, const spmatrix_t *spm, spm_int_t n, const spm_complex32_t *A, spm_int_t lda)
double d_spmNorm (spm_normtype_t ntype, const spmatrix_t *spm)
double d_spmNormMat (spm_normtype_t ntype, const spmatrix_t *spm, spm_int_t n, const double *A, spm_int_t lda)
float s_spmNorm (spm_normtype_t ntype, const spmatrix_t *spm)
float s_spmNormMat (spm_normtype_t ntype, const spmatrix_t *spm, spm_int_t n, const float *A, spm_int_t lda)
Detailed Description
Function Documentation
◆ z_spmNorm()
double z_spmNorm ( spm_normtype_t ntype,
const spmatrix_t * spm )
Parameters
[in]ntype= SpmMaxNorm: Max norm = SpmOneNorm: One norm = SpmInfNorm: Infinity norm = SpmFrobeniusNorm: Frobenius norm
[in]spmThe spm structure describing the matrix.
Returns
The norm of the spm matrix -1 when error occurs or with pattern only
Definition at line 1214 of file z_spm_norm.c.
References SpmFrobeniusNorm, SpmInfNorm, SpmMaxNorm, SpmOneNorm, z_spmFrobeniusNorm(), z_spmMaxNorm(), and z_spmOneInfNorm().
Referenced by spmNorm(), and z_spmGenRHS().
◆ z_spmNormMat()
double z_spmNormMat ( spm_normtype_t ntype,
const spmatrix_t * spm,
spm_int_t n,
const spm_complex64_t * A,
spm_int_t lda )
Parameters
[in]nThe number of columns of the matrix A.
[in]AThe matrix A of size lda-by-n.
[in]ldaThe leading dimension of the matrix A. Must be >= max(1, spm->nexp).
Returns
Definition at line 1278 of file z_spm_norm.c.
References spmatrix_s::clustnbr, spmatrix_s::comm, LAPACKE_zlassq_work, spmatrix_s::nexp, spmatrix_s::replicated, SpmFrobeniusNorm, SpmInfNorm, SpmMaxNorm, and SpmOneNorm.
Referenced by spmNormMat(), spmNormVec(), and z_spmCheckAxb().
◆ c_spmNorm()
float c_spmNorm ( spm_normtype_t ntype,
Parameters
Returns
Definition at line 1214 of file c_spm_norm.c.
References c_spmFrobeniusNorm(), c_spmMaxNorm(), c_spmOneInfNorm(), SpmFrobeniusNorm, SpmInfNorm, SpmMaxNorm, and SpmOneNorm.
Referenced by c_spmGenRHS(), and spmNorm().
◆ c_spmNormMat()
float c_spmNormMat ( spm_normtype_t ntype,
spm_int_t n,
const spm_complex32_t * A,
spm_int_t lda )
Parameters
Returns
Definition at line 1278 of file c_spm_norm.c.
References spmatrix_s::clustnbr, spmatrix_s::comm, LAPACKE_classq_work, spmatrix_s::nexp, spmatrix_s::replicated, SpmFrobeniusNorm, SpmInfNorm, SpmMaxNorm, and SpmOneNorm.
Referenced by c_spmCheckAxb(), spmNormMat(), and spmNormVec().
◆ d_spmNorm()
double d_spmNorm ( spm_normtype_t ntype,
Parameters
Returns
Definition at line 1214 of file d_spm_norm.c.
References d_spmFrobeniusNorm(), d_spmMaxNorm(), d_spmOneInfNorm(), SpmFrobeniusNorm, SpmInfNorm, SpmMaxNorm, and SpmOneNorm.
Referenced by d_spmGenRHS(), and spmNorm().
◆ d_spmNormMat()
double d_spmNormMat ( spm_normtype_t ntype,
spm_int_t n,
const double * A,
spm_int_t lda )
Parameters
Returns
Definition at line 1278 of file d_spm_norm.c.
References spmatrix_s::clustnbr, spmatrix_s::comm, LAPACKE_dlassq_work, spmatrix_s::nexp, spmatrix_s::replicated, SpmFrobeniusNorm, SpmInfNorm, SpmMaxNorm, and SpmOneNorm.
Referenced by d_spmCheckAxb(), spmNormMat(), and spmNormVec().
◆ s_spmNorm()
float s_spmNorm ( spm_normtype_t ntype,
Parameters
Returns
Definition at line 1214 of file s_spm_norm.c.
References s_spmFrobeniusNorm(), s_spmMaxNorm(), s_spmOneInfNorm(), SpmFrobeniusNorm, SpmInfNorm, SpmMaxNorm, and SpmOneNorm.
Referenced by s_spmGenRHS(), and spmNorm().
◆ s_spmNormMat()
float s_spmNormMat ( spm_normtype_t ntype,
spm_int_t n,
const float * A,
spm_int_t lda )
Parameters
Returns
Definition at line 1278 of file s_spm_norm.c.
References spmatrix_s::clustnbr, spmatrix_s::comm, LAPACKE_slassq_work, spmatrix_s::nexp, spmatrix_s::replicated, SpmFrobeniusNorm, SpmInfNorm, SpmMaxNorm, and SpmOneNorm.
Referenced by s_spmCheckAxb(), spmNormMat(), and spmNormVec().
